Another MAT input?
UR50SLO
V6+2=LSXCamaro
Any way we can add a port input to the ECM to watch another MAT sensor?
I'd like to see what the temps are coming out of the turbo and then compair them to the
real MAT in the intake to see how well the intercooler is working.
On the way up to the event going down the 80/90 toll road at 70-75mph the actual MAT
was at 85degrees. Not sure how warm the outlet from the turbo was?
Even sitting in traffic/slow it never got over 100deg. Coolant temp was 171deg.
Any Idea how do make another Input? Jeff? Dig?
Thanks for any help! :tup:
Scott~
ed hess
race or get outta the way
Re: Another MAT input?
Scott~
simpler way would be to use a 2 port computech egt setup. put the additional 2 senors anywhere you want them.
ed
turbodig
Scott~
The input is already there... there would need to be additional code to read/process/spit it out to ALDL. Not trivial.
If you're already using the innovate wide-band, look at the TC-1 box. It'll take 4 thermocouples and send the data to logworks. You could do ambient(outside),turbo inlet, outlet, and ic outlet.... then you could corellate efficiency to the outside temp, etc.
UR50SLO
V6+2=LSXCamaro
The input is already there... there would need to be additional code to read/process/spit it out to ALDL. Not trivial. Meaning not fun right.....
I'm using a AEM wideband with code 59. It doesn't have any additional inputs.
I could put a changer out there to switch from one to the other. but i'd only be able to monitor one at a time. It's not a big deal but I thought if it was somewhat simple it'd be nice to see how different the temps are.
Thanks for the ideas guys!
~Scott
mattw
Are you using an autoprom to do your data logging? If so its got 3 or 4 additional inputs that can be logged in tuner pro..
-Matt
turbodig
Meaning, if you start now, you might get one developed in 2 or 3 years... :)
~Scott
You could still use the TC1, I think. Most of their remote devices will work with logworks alone. I wouldn't be surprised to find that AEM had a similar product.
Later,
turbodig
-Matt
This would work, although you'd need themocouple amps if you were using k-type thermocouples. If you were using the GM-style resistive sensors, you'd just need a 5v source and a few resistors to set up a voltage divider for each one.
UR50SLO
V6+2=LSXCamaro
I did get a extra input for 0-5v with the autoprom from Moates.
I'll check into that some more... I realy would like to see how well that intercooler's workin.
I think it's doing alright. There's more than temperature drop to a intercooler system. Got to look at the pressure loss too. Now I'll have to look into duel boost gauges too. Lol.
The guy from RJC runs one EGT per cyl. He ballances his intake air flow this way.. along with other methods. I think he's still got the fastest stock block (TSM) car. 9's with 3500lb car 70GTQ turbo.
Check out more at www.RJCRacing.com
~Scott
turbodig
~Scott
I've seen some fairly elaborate (read: expensive) datalogging setups. WB per cyl, EGT per cyl, and cyl pressure vs. crank angle (done in 1/2 degree increments)... wild stuff.
You learn a lot about cylinder balance, this way.
