Re: Another one bites the dust!
Hey guys, wb was never leaner than 12.5, timming was 17 deg max at 19psi, never detonated (always logged) knock sensor works good (checked it with the ignition on, engine off, tapped on the head)
bezerk could be right, It does not smoke, or has a miss. After oil change, i heared that lifter again for few seconds.
Oil psi is normal ( 70psi cold, 40psi hot idle )
