So are you ditching the power steering pump and running this as a manual rack?
A kit wouldn't be a good idea. Considering what is involved it wouldn't be worth selling IMO. Like I said, the front dif mount needs to go and that is job you don't want to do with the engine in the truck. Once that gets cut out you have to weld something to support the motor mount. I'll take pics of what I did.
I checked the angle of that joint, its only 25* so it should be just fine. And to make Austin happy and went bought some shinny new bolts all at the correct lengths. :lol:
I can take a pic of that. I still have to get rid of the headers though because I built them for my 67GTQ and Vortec heads. They don't fit the Bowtie heads I got nor do they fit for the 76mm turbo I got.
I actually got the flex joint through Summit but I believe it was a Vibrant part.
The stock manifolds do NOT fit with my set up. I think Matt got his to fit using an Explorer joint.
I did use an explorer joint but I'm running a 5.7 with log style manifolds that I made.. I have no clue if my setup would clear a stock manifold/crossover or not..
