Antifreeze Leak
Turboz
NASTE
Through search I see that there is a freeze plug behind the pass side motor mount and I am almost positive that is where my leak is from. My question which I am already guessing the answer to. Is it possible to replace this with the engine in the truck?
Re: Antifreeze Leak
Yes, I've done it. I'll dredge up the pics/how to.
EDIT Here's the link:
http://www.syty.net/forums/showthread.php?t=45264&highlight=freeze+plug
To me this worked amazingly well. Although I used an old motor mount you could easly use an existing mount to make the plate so the bolt holes match. Hope this helps.
EDIT again, BTW DO NOT use the pan to support the motor. Clearances are close between it and the rods. Ask me how I know...
Turboz
NASTE
Re: Antifreeze Leak
Thanks for that I did not come across that post in search. Looking at the pictures, looks like you have the down pipe out and starter out am I correct. Also were did you support the motor?
Re: Antifreeze Leak
You can support the motor on the front pulley if I remember right. Starter out for sure. After that you're gonna have to play by ear. I honestly don't remember what else I removed.
Ya Justin. I was looking at that leaky plug thinkin' what the h am I gonna do now. I was amazed I even thought of it. Necessity is the mother of invention I guess...:roll:
