Any ecm placement tricks
Ian Turgeon
Cascading Inspiration
Now that I've got my autoprom and moate's adapter (w/zif) I'm trying to think of a better solution then hanging the ecm on the floor... anyone done anything interesting in placing the ecm where its easy to get at?
nallj92
Re: Any ecm placement tricks
ditto on the glove box, run the wire throught the access hole and put it all in there fits like a glove
Ian Turgeon
Thats kinda what I was thinking so I'll definately have to give it a try.
93ty475
Here's a suggestion for mounting the ecm....takes only 10 minutes to do....you can wet the two ecm mounting bullets with some whiteout to mark the spots in the glovebox to drill out the left inside of the glovebox (1st pic below).... then use 2 ecm screws on the opposite side of the ecm to attach a small piece of aluminum angle to it (second pic below)....then just screw the ecm to the bottom of the glovebox with a short wood screw and an angle drill attachment....if you don't like the idea of drilling holes to make this permanent, i guess you could use velcro....the way i did this below is extremely solid for such a small effort.... regardless, the glovebox is a much better spot than the ecm hanging in mid air on the passenger side floor....i also enlarged the prom opening in the ecm for easier chip/adapter replacement and removal.....
keith455
Average Joe
Staff member
I removed the VSS and bracket to fit the ECM in this area. Then I took a piece of flat stock and twisted it and mounted it with 2 existing bolts. One under the dash and one off the ECM.
Crimson93Ty
PITA new guy
Ok, Servando, what's the story on the gauges and plate off to the left of the ecm there? I know it's off topic but if you've talked about it before, can you send me a link? That's really nice. :tup:
skwayb
NWSTP
I installed my Autoprom in the glove box and ran the cable through the back of the glove box into the ecm. You have to be careful doing it like this. The pins on the cable end that go into the Zif socket on the Moates adapter are softer than you think. They break off easily once bent. I hooked my Autoprom up be installed permanently and leave it in my Ty all the time now.
I have an entire picture album of the install at:
http://www.nwstp.com/forum/photo_album_view.asp?cname=AutoProm&mid=18&cid=49
Here are some pictures of my install.
93ty475
[hijack]
nallj92 posted the correct link...sorry I didn't see this until now....I promised to write up a how to and never did....I'll update the thread with a great fiberglass how to that i found on another forum.....much better than any how to I could write up....thanks
[/hijack]
