Anybody ever use solid lifters
BigAl...
I'm wondering if anyone ever switched over to a solid cam/lifter setup. Maybe some of you guys with the billet cranks that rev 7krpm. Do the SBC solid lifters work in our engine?
TIA
BigAl...
ed hess
race or get outta the way
al
i may be wrong but i think the only owner that comes to this board reving to 7k is hoover!
If i remember tonite I will ask harry when i get to atco if tom ferrick is running solids.
ed
ken's right there on the comp lifters - they just became available again - i am sporting a set myself.
no flames, but i think solids would be way dumb.
first, ever heard a set?
yer knock sensor will love 'em!
second, why go backwards in cam profile rise rate?
last, friction, and all flat lifters/cams will eventually take a shit - a roller cam should last forever.
ed hess
al
I saw harry last nite.
Tom ferrick is running solid lifters, and yes he does rev past 7k rpm.
hth
ed
They do make a solid roller.
Although I don't plan to run solid in my ty. 1 car with solid is enough for me.
I will suggest, if you do go solid, beef up the valve train as much as possible.
7/16" studs, girdle, etc. Will help prevent the constant lash adjustments.
Has worked on my 350 with solid. Probably 15k miles now, without any major adjustments needed, just checked a few times.
sorry, AL - i shoulda figgered that out myself.
jeff's right, tho - use premium parts and the lash adjusts are less frequent then most would tell you - assuming the cam is set up as a street roller type of profile - with ultra fast race ramps you will need to adjust at least somewhat more often.
i'd still be a LITTLE leery of knock sensor hassles, tho much quieter then a solid flat.
bear in mind a juice roller CAN be made to go to 7k with the right parts....
however a solid is always worth more power by a few % at least, combo dependent....
