check out this post from the syty.org archives about the bravada smarttrac:
http://www.syty.org/archives/syty/9910/msg01840.html
In a message dated 10/29/99 01:39:36 PM Pacific Daylight Time,
lewp@xetron.com writes:
> It is not clear to me how the 'SmartTrac' system would help the higher speed
> driving (solenoid or not) as the weight and drag of the AWD is always
there.
I've been following this thread, and here's my observations so far:
There was a post a week or two back regarding optimizing front and rear tire
pressures so that rolling distance was the same front/rear. This is probably
the easiest/most effective thing to do to reduce drag from AWD. I couldn't
find the post, but it was very detailed as to how this guy did it, and made a
BUNCH of sense. Perhaps he'll repost it.
Re 'Smarttrack'.
1. Remember that in 2WD ALL of our power is going to the rear axle. The
7-5/8 axle is probably beyond it's design limits with 365+ ft lb. of torque
being applied. You dudes that are 'built,' will be pushing it. Ask Jerry
McCoy.
2. The front axles, R&Pinion, and D/line is still turning. This is drag.
3. The new T-case (solenoid engaged) is HUGE. I've looked under a few of
these. It's GOT to weigh significantly more than our JK-type.
4. I don't know what electronics would be required to 'engage' the
solenoid. In the Bravada, the solenoid is activated by the VCM. It uses the
ABS sensors to detect the 'slippage'. I'm sure it doesn't just 'throw a
switch' to engage the front axle. It's probably applied incrementally.
5. You give up the AWD for normal driving. I think AWD is actually pretty
cool stuff. Especially in rain. Helps with braking as well, because all the
wheels are mechanically linked.
So: Add weight, add stress to the rear diff, don't decrease parasitic drag
much, give up AWD, and need to engineer electronic controls. Doesn't seem
very feasible. Plus we haven't addressed whether this is a bolt-up to the
stock trans output shaft and trans adapter housing.
My . 02
Davep
