cvcsmkr
i have been working on my iat's.
i have a blanket on the turbo, and the cold side of intercooler piping wrapped.
i wanted to see if adding side blades would make a difference.
so i datalogged the temps with just the stock blade.
i was getting as low as 110* but stayed about 120* and went up to about 130* by the end of a quick boost run(16 psi)
with the blades on the side i was seeing as low as high 90's and stayed about 105* and would get up to about 120 after a quick boost run.
and the temps came down much quicker after cruising a little bit with the blades on the side.
heres a pic of another members setup, whichi will definitely be doing.
