truckins10
I was thinkin guys
, wouldnt it be nice to eliminate all the common steering wheel freeplay and hassel of constantly replacing pitman arms and idler arms?? If you could find a vehicle with the same width(from tie rod to tie rod) to the stock setup, make a couple custom brakets, then wouldnt it be fairly simple to convert over. Youd have to reroute the lines and make brakets to bolt 2 bolts for the rack and pinion. Would it be worth the hassel?? I was thinkin you would also have to find it odd a vehicle with a fairly quick steering ratio. Fern Sy#477
