Anyone ever deal with?
Syonara
Wallers tranny blew up(under 2K on the clock)--and just wanted to put out some feelers on tranny shops:anyone ever delt with ProBuilt? out of CA.?
Silly
Banned
Re: Anyone ever deal with?
No sort of warranty? What broke? I personally say that unless you MUST have OD just get a th400/th350
Syclone Rob
Its all ABOOT the SYTY eh
First I would see if waller would do anything... if not.. then I would just spend some extra dough on a 4l80e.. Unless of coarse you need a tranny now and with limited funds.. but if it was me, I would just park it till a 4l80e can be put in....:tup:
Deanzsyclone
George Blake tranny would be the only way I would go. Ship him yours, he'll ship you another built trans.
Jimmy
Banned
Dude John stands way behind his stuff.Give him a call,he will fix it for cheap.
chelo
filthy sy
You bought the truck with the waller trans already installed right?. Was everything set right? Tv cable?
gjp
another post whore
from what I read on here, he builds good transmissions. Unless something was installed wrong or you are putting down some serious HP I cant see his trans. going out that fast. George builds great transmissions too. I have George's 80e and all I can say it it takes a pounding. I would not trust anyone but them two on any of my trans.
George Blake
DONATING MEMBER
Make sure you talk to John. 700's can only take certain kinds of punishment. If you were shifting it up and down manually, it was just a matter of time. Unless you put big money into a 700 it won't last long under certain types of abuse. Unfortunately, if you put a lot of money into a 700 and you may as well done an 80e. We all know you didn't brake it driving to the grocery store doing the speed limit. The 80e that a lot of these guys do is a big conversion. But, if you beat on the truck, it may be the only answer if you want OD. Now other things can kill a 700, TV cable not set right, stuck TV valve in the valvebody or a stuck pressure regulator valve. These no builder can control because just one little piece of grit can break lose or get flush through a cooler and can make any of those components stick. It makes it shift to hard and it breaks. Any trans installed with a TV set up MUST have a full pressure check done to make sure no valves got stuck and the the installer got the TV correct and no lines are kinked(flow test after the cooler). There is a lot of responsibility on the installer.
Syonara
Just pulled out of a parking lot, 15-20mph, 1-2 was normal......then 2-3 shift--"bang" i thought i ran over a speed bump ...gave some gas, turbo spooled and no power........i had first and sec. with no problem--and i was done at that point. Wasnt racing or beating it--just left the store. The truck hasnt been raced since the tranny was put in, hasnt been to the track......fluke?
I would send it back to John. We broke one that was making 440 at the wheels on 16psi and pump gas. He fixed it for nearly nothing, and it's working great again.
Tooky
Serious about performance
If for some reason you still are in the market for another 700R4 rebuild, ProBuilt Automatics (http://www.700r4l60e.com/) is a spectacular company who impressed the hell out of me. It seems primarily run by the owner "Dana" who is one of the most knowledgeable and helpful transmission gurus I have ever met. He didn't have much actual experience with SyTys but he still knew more about our transmissions than I ever expected. He has more information on specific valves used in different trannies than I have heard anyone else ever talk about. The guy sat on the phone with me for hours offering to give advice on how to fix my tranny built by another builder, I actually had to end the call just because I ran out of time.
Dana has earned great respect on the ThirdGen.org site where he builds a lot of 700R4s for TPI F-body owners and has also written many DIY tranny rebuild articles. He also has a customer who bracket races a full weight, 9 second, 140+mph F Body with a 700R4 that has not failed, and he has evidence to prove it and the racer's web page also confirms this.
See for yourself on pro-built.net:
And paying close attention to details & clearances, I am able to get many vehicles in the 11's, quite a few in the 10's, a few in the 9's, and the quickest/fastest of these is a 3,560 lbs w/driver street driven 1995 Firebird with a 2000 LS1 motor & trans, he built the transmission himself using the Pro Street Performance Upgrade, and has run a best of a 5.78ET @121mph in the 1/8 mile, & a 9.36ET @144.6mph in the 1/4 mile. He has now over 300 passes with this transmission.
Ed Wright of www.fastchip.com uses my Performance Upgrade in his high 9 second 1996 Firebird with hundred's of successful passes on it.
It seems that ProBuilt has the title of producing the 700R4s that have lasted in the fastest cars, unless someone knows of a 700R4 that has gone faster than 9.36 @ 144 in a full weight vehicle. If I would have known about Dana @ ProBuilt before I had my 700R4 built, I would have gone with him.
autoaddictions
Dont know if you intend to race the truck But if you do, cut your losses and get PG to build you a 80e. Its the best mod on my truck im sure id of went threw 3 transmissions buy now if i didint get a 4l80e. If you bought the truck with Waller trans in it already im not sure he will do much about it. But good luck anyways.
Doing 9.36 is very impressive but it still different than doing 9's in a SyTy. Atleast in this case our truck are still about 200 lbs heavier than most Sy's and 500# heavier with Ty's. Maybe we could knock 50# off with Tooky driving ;) The bigger difference I beleive is that AWD adds that much more drag and stress to the tranny. I don't know what the equavilent stress but I do know its very noticable in terms of 700 life and how they break.
I know C4 Corvette pretty well (I own one for 12 years, plus I was on the internet reading up on them regularly from 94-03), so I will use them as an example. With basic fresh performance transmission rebuild (the rebuild kit that cost $200 more than a basic rebuild), I saw many of them reliably putting down mid to low 11's track and doing regularly, some guy raced every weekend. C4's are 300-400# lighter, have much less torque (HP is usually similiar to Torque), it takes about 450hp and drag radials to do mid 11's. Most of them have 1.5-1.6 60's times. When the they failed the clutches usually slipped. SyTy don't ususally get into the 11's for too long with the stock transmission, and more importantly I see a ton more failures with parts breakage.
MikeRenz
not stock
that happened to my waller tranny when my tranny pump exploded. He'll fix it, just sucks having to yank and ship the damn thing.
JustBeachin
Plays well with others
I've heard nothing but great things from Jimmy about Waller, and it sounds like everyone else is in the same camp. I don't wanna repeat what anyone else has said, but..."Contact Waller"
Raist103
same thing here pump died at 300 miles but he took care of it.
TYTILIDIE
METH HEAD
I bought two turbos from him and have nothing but good things to say about the guy., He answered all my tech questions and gave me the support I needed. Im sure he'll fix you right up.
cloneman315
i have had about 1500 miles on mine not one problems i have his top built 700,but like these guys say call him, he def will help u i am sure of this.And personally i would not try to find a syty trans guy ,u really need to have someone that knows these trucks and trans ,or u will be not happy
Syonara
We pulled the tranny out--opened up the unit....front pump distroyed, clutches/bands distroyed, and gears blue with missing teeth......looking at all new internals.
*Ended up going with a built TH400 automatic w/transbrake.
