Anyone have an old PS pump?
Loeryder
I turned my core in already and the new pump does not have the 2 studs in the backside of the reservoir.
They are where the steel bracket from the exhaust man mounts to the pump reservoir.
Can't frickin believe they don't supply them on reman'd units.
This new pump has plugs where the studs go so I assume the threads need to be sealed.
The bracket has to clear the PS return line so it requires a stud, simple bolt won't work.
The bracket has to be spaced away from the res by about .25".
Didn't someone say they just left out this whole bracket?
or was it just at the exhaust manifold side for custom non stock manifolds?
grrrrrrrrr
myclone
sorry bro but the front accessories are spoken for on the 90 jimmy Im parting out. :( It they werent needed Id hook you up.
jwaller
Evil Genius/SyTy Guru
yes almost everybody I know that runs headers leaves this bracket off. you don't need it. :fist:
Lynn D. Brown
PS Pump
PS Pump
Jas',
I'm sure U aren't the only one that left the studs on the pump when they turned in the Core. Did U go back to the AP store where U bought the pump and tell them about it ? I would think that the rebuild Co. that does the pumps has plenty of spares. Or, if U have to, maybe these studs can be ordered from Dal - GM.
Loeryder
Yeah I went back to where I dropped my core and they were less than helpful.
All they could tell me was the cores went back to their distrib, then they wanted to sell me a bunch of studs and bolts they think would work.
Calling around no one has the studs and the bolts you have to buy a bag of 10 so I am thinking I'll just toss the bracket since many with headers delete it anyways.
I can get them from www.gmpartsdirect.com for $28 shipped...
bwahahahahahaha
Thus why I am hoping someone comes across something for me here.
Nearest boneyard is a half hour drive and then I have to find what I want, those guys are the least helpful I've ever seen.
So if anyone goes by a junkyard and can grab the 2 studs and 2 nuts Id be greatly appreciative.
Loeryder
bump...
Seriously though, if anyone is going to the boneyard anytime soon, please check for me.
Nearest decent yard is a 25 minute drive.
Loeryder
The Studs are GM #7833293 and I wound up having to order them from a local dealer.
GMpartsdirect.ripmeoffonshipping.com wants $7.95 to ship 2 studs and less than 2 oz.
