Anyone know why this happend?
spooldup
Super Member
Hi guys. I was told to remove the atr underdrive pulleys from the ty. They were screwing up my voltage and creating knock. Anyway i did so and what happend when i put the stocker back on was my tps voltage dropped to like 4.2 something and my o2mv's went lean again. Why did this happen? O it also shave 1 degree of knock from the truck but i am still hitting 7.7 at 15lbs of boost. maybe i should raise the fp up more? It's at 50.
jwaller
Evil Genius/SyTy Guru
not sure dude but stock pullies are the way to go...
BTW TPS voltage doesnt matter. the % is the important part.
spooldup
Super Member
o hey john whats up? Actually you are the one who told me to remove them. About the tps volts. My mechanic still insists that i need 4.5 volts to go into open loop. He says that the truck should go into open loop otherwise the computer is not giving the motor evrything it has as in fuel and stuff. I know that you told me that the truck does not go into open loop and i TRUST you. He just wanted me to put that piece of info in here. Anyway whats next to get rid of knock? Do i have to raise the fp again? I bought the ur5ix's, redline, and gm tec for this weekend. Will this help? I also found out that when my new motor was put in that they changed only the cap and rotor. They used oem parts. So whats left that will give me knock? I also have a new datamaster file after the pulley was installed. Do you have the time to look at it for me? Thanks john!
_________________
92 Ty#2212
url]
<font size=-1>[ This Message was edited by: 92 black typhoon on 2002-04-03 21:32 ]</font>
ticlone
Esss in the house!
J-Dub, what is the 411 on the ATR under drive pulleys? I'v had mine on for about 5 yrs. I'm just curious, because I have never heard anything bad about them.
Thanks,
Syclone #1987
spooldup
Super Member
well from what i am told and have seen on dm is that is lowers your voltage severly and it slows down your waterpump. They are bad for the truck and from what i am also told only and increase in performance is seen above 5000 rpm. Listen to john. he is VERY smart with our trucks. get them off your ride.
jwaller
man you need to change those parts and do a full tune up. conrad cap and rotor if you can get one.(autozone). send me the file and I'll look it over. and no the volts dont matter. it did on older ECM's but not ours. look at the % only. you might need more FP but we'll see when I have the file.
ticlone
Esss in the house!
Dag-gone-it! Just when i thought, all I have to do this weekend is finish polishing my wheels and I can put her back on the road.
Oh well, thanks for the heads up!
spooldup
Super Member
well this might help also. My mechanic says that my ecm is NOT the original that came with her. Do you need to know what it is?
jwaller
no if it is in your truck and working then I wouldn't worry. as long as its a factory replacement or rebuilt or something. it is a syty ecm isnt it? there isnt a cut and hack job under the dash is there? everything plugs right in correct?
Daron
Again, your mechanic is incorrect. When you start your truck, the ECM takes the closed throttle reading ( somewhere below 1.1 volt) and calls this voltage level "0%". From that level it only takes approx. 3.15 volts for the ECM to report a "100%" throttle opening. So, if your truck is like mine, the TPS drops .6 volts at closed throttle. All you would need is aprrox. 3.75 volts at WOT for the ecm to report a 100% throttle opening.
Mr. Sealander was kind enough to beat me over the head with that years back, after I had quoted the SyTy supplement. The SyTy supplement would lead you to believe something totally different than the above.
Now, hopefully one of the gurus will pipe up here if I am wrong, but your truck will go into open loop sooner than 100% tps. I wanna say it is more like 90 percent or so.
Ignition and fuel. Most common knock issues are rooted here.
Start over, ignition wise. New plugs, wires and cap and rotor. Change your fuel filter and see where you are then... Oh, maybe ditching your mechanic and doing the stuff yourself is the best advise I could give.
_________________
Daron
1992 Typhoon Blue/Gray
1991 Syclone Best 1/4 12.42 @ 106.1
Member Of Freakin' Ohio (MOFO) SyTy
<font size=-1>[ This Message was edited by: Daron on 2002-04-04 08:46 ]</font>
ParTyBoy
The one thing that concerns me over this post is this statement
They changed only the cap and rotor.. and they used "OEM parts" .. This should be the clue right there....
You have good plugs.. I'm assuming they are the right NGK's.... First. you need a conrad cap and rotor kit from autozone.. Second.. get some "good" wires... either ATR black beauties.. or possibly the taylor spiro's.. Daron says he's tried them and they worked well.. same with the chi-town peeps.. I just ordered 2 sets from summit.. guess I'll find out for sure...
And I almost forgot.. until I re-read all the posts.. replace your fuel filter... From all the neglect the previous owners put your truck through there's no telling how long the old filter's been on your truck.. It'd be a good idea to replace it.. could be restricting the flow of that new pump that you just installed...
<font size=-1>[ This Message was edited by: ParTyBoy on 2002-04-04 09:53 ]</font>
spooldup
Super Member
Just to update. I have ordered new ngk ur5ix plugs. I have installed new atr wires. A new fuel filter was installed when the motor was swapped approx 300 miles ago. I will be running redline in a couple of minutes. I bought gm tec for this weekend along with fresh oil and filter. I just picked up the conrad cap and rotor. That will go in this weekend. I appreciate everyones help here. It just seems like a never ending battle. I buy everything and nothing works. Kinda depressing.
ParTyBoy
Have you contacted Peter Humblias yet?? That should work... He's back in jersey..
here's his email: sytynut@hotmail.com
ParTyBoy
On 2002-04-04 22:00, 92 black typhoon wrote:
This is starting to make me nervous. I wonder if something is wrong with the motor again?
go to AOL... and download AIM here:
http://aim.aol.com/aimnew/Aim/register.adp?promo=248496
once you have it installed.. come back here
and post your screen name...
and for the last time... do yourself a favor. contact Peter at sytynut@hotmail.com
and the NASTE guys... .. go here:
http://www.tcnj.edu/~mikulet2/syty/members.html
contact somebody please.. I wouldn't let your mechanic touch your truck anymore until Peter looks at it... and if you don't trust this advice.. well then good luck man cause I really don't know what else to say..
spooldup
Super Member
I contacted peter. Waiting for a reply when he reads his mail. John waller has been a great help with this also. I owe him bigtime!
spooldup
Super Member
Ok my screen name is black92ty.
<font size=-1>[ This Message was edited by: 92 black typhoon on 2002-04-04 22:45 ]</font>
spooldup
Super Member
Can the fuel lines that run on top of tranny cause knock? I hear them tapping away. My mechanic says that the brackets that are supposed to hold them are missing. Does anyone have them?
