Anyone Recognize This TPS?
TYTILIDIE
METH HEAD
It has a grey (5v ref?), black (ground?) and Orange (signal?). If anyone recognizes this thing, anyone know if the positions resemble a SYTY? My guess would be they would be the same since the throttle blades turn the same distance as a SYTY.
DaveP
Re: Anyone Recognize This TPS?
That's a OBD2 TPI TPS, 96+
Really?
There's no difference electrically between OBD I and OBD II. I've never heard or read any refrence to the OBD system making a difference for TPS sensors on GM's.
My 1993 L35 CPI 4.3 engines use that sensor. 1993 is several years before 1996.
0966Sy
Code what?
I was thinking of the late LT/LS sensor, looking again it does have that P shape. My 92 CPI has the same sensor.
syclonejim
Looks like a 97 Z28 TPS
DaveP
So hook it up and go?
I think so. It should be fine. It's a 5volt sensor for GM apps.
Like with any major new configuration, you should verify all the pin-outs with a VOM, then power-up the system and check all the signals, inputs and outputs on a scanner or your laptop prior to attempting to start it.
