Anyone wanna help with a Datamaster file?
raman117
I just purchased a Datamaster setup from Detroitturbo.com, and was wondering if any of the gurus would be interested in taking a look at it? It's a 93 Ty with 25k original miles on it, pretty much stock except for the standards (walbro, better cap/wires/cap/rotor, etc.). Here is a link to the file: http://firebochs.com/5-14-2009.uni
I'm not sure if I had enough WOT driving to make the test worthwhile, I'd be happy to log it again if there is a better way of doing it.
Trapper
Re: Anyone wanna help with a Datamaster file?
Well you start out slow and work yur way up, are you trying to do your own auto tune? Go to code 59.org to do some reading too.
raman117
I guess I'm more interested in making sure everything is up to snuff. I don't race it, I just want to find out if I'm having knock issues or any other anomalies that I should fix.
Go do a 0-60 run with a mild boost launch and full throttle to 60 or so and post that run. If it acts funny or you hear strange noises like knock (ping) let up and post it anyway.
raman117
I have attached a screenshot of the datamaster file. I'm concerned about the spark retard, what is the best way to prevent this? I'm running 91 octane gas, which is the best available in my neck of the woods. I can't hear pinging or any other strange noises, but obviously it's happening.
WyoSyclone
If it's mostly stock, I wonder if you have either a fuel pump going bad, or a clogged filter. Your injectors are wide open (static) trying to meet your AFR target. Look at what your vacuum is at idle... if it's low, maybe you have a vacuum leak which may be affecting your fuel pressure via the regulator.
I'd sure hook a fuel pressure gauge up to it and see what you get before you make another WOT run.... over 10 degrees of KR won't do it any good.
Also, looks like you topped out at 3700 rpm at the shift... about 800 or 900 too low with a 100% TPS.
Look to see what DTC is thrown.
raman117
Thanks for the reply, here is a screenshot of the DTC error:
Every once in awhile when I'm driving down the highway at 60-70, it'll throw a check engine light. I haven't had my DM in the vehicle when it's happened so I haven't been able to grab the code. Once I restart the vehicle, the light goes away and stays off until I get on the highway again. It has a Walbro fuel pump, but I'm not sure that the fuel filter has ever been replaced. I'll grab a new one and swap it just to be safe.
