Aquamist/water/alky injection setup
charles
My combo so far is PTE54 kit, ultimate with 50's, open exhaust, 3,000 converter, engine and i/c setup all stock and i'm throwing aquamist on soon.
Of the guys running alky/water injection, what have you found to be the best point to set it to come on?? I was thinking somewhere around 10psi ??
Lynn D. Brown
Aquamist actuation
Aquamist actuation
U didn't mention what U had 4 a fuel pump. Hopefully U have upgraded, because the stocker may be short w this combo. Assuming U have upgraded, 10 psi is typical. U can dial it in by recording a run w a scanner.
Buster
Re: Aquamist/water/alky injection setup
I turn mine on at the lowest setting on my Hobbs switch, which I think is 4 psi, only problem is it takes about 1 second for it to actually hit and by that time I'm at 26 psi. I'm working on a new system that'll have pressure all the time and then activate a solenoid right before the nozzles, should solve the delay problem.
With regard to your system, you might want to use a pump that'll hold up to methanol better, because there's big gains to be had, water works but not worth the effort IMO.
I've got some logs with 24-26 psi , 20 degrees of timing, no knock on 92 octane, with water I was picking up a little knock at 20 psi.
Sy769
I haven't installed my system yet. I have a solenoid so I can turn it on and off quickly. I also use a pressure regulator so I can change pressure easily and the excess water is routed back to the tank.
When I get it installed and sorted out I planon doing a write-up with pictures,part numbers etc.
From all of my reading I am going to try 10psi turn-on first.
Falco
My one turns on at 8 psi. 50% water, 50% methanol. However I'm very impressed by Mark's results, so might try pure methanol, larger jets (I'm running two 0.6 jets right now) and I'm even thinking to drop that IC. 8)
Mark! You are using a Ford pump, right? What kinda Shurflo pump could be used instead of the Ford one? Where can I get one? Home depot or someting like this? I'm affraid that pure methanol will eat my Aquamist pump soon enough, and I don't wanna buy a new one for $200+. AFAIR the Surflo is dirt cheap...
Later,
smeagol
FWIW, not trying to post for sale in a tech thread, i have some good components for someone interested in a DIY alky/water setup
Shurflo pump
Aquamist nozzles
check valve
solenoid
Aquamist line & fittings
Hobbs switch or two
get in contact with me about it - I was building a 4 nozzle staged system, but I've gone with propane instead. I was going to keep it in case I don't like the propane, but I need the cash.
2cold
Buster, you probably already know, but you can use an accumulator to get rid rid of the delay your talking bout.
Buster
Actually I didn't know, thank you! I'm looking into a high pressure system (250 psi) , basically pressurizing the water tank with a small 12v air compressor, not sure its worth the trouble but some thing to think about.
Buster
Later,
Not anymore, I just bought the shurflo, I'm told the ford pump won't live with methanol, and that could be a bad thing at 26 psi.
Buster
Later,
I think dropping the intercooler on my truck was a wise decision, I felt like the stock intercooler would be a restriction, actually I know it is, and upgrading to an aftermarket intercooler has been nothing but a pain in the a**. Either they don't fit or they don't work. The spool up, intercooling, and octane I'm getting from my system is pretty crazy, especially considering the small amount of $$ involved.
keith455
Average Joe
Staff member
Mark,
Do you have any pics of this setup??
I'd like to ditch the stock IC plumbing in my TY.
Buster
Hey Keith, I'll snap a few shots and send them to ya, at this point it's just a temp setup, but it works.
Here are the parts I'm using.
(1) 3" to 4" TB reducer hose from ramchargers.com
(1) stock syty orange turbo inlet hose
(1) small 3" 90 degree mandrel bend from Napa
(4) super heavy duty t-bolt clamps from a local Mack dealer.
HighPerformanceTrucks
Lift & Shift Specialist
I run a system 1s and have the pump activate at 10 psi. This gives the system time to actually start flowing water into the manifold. I've found the highest number of KR occurs when the truck hits 3rd gear.
I also use the Aquamist Flow Meter to see water flow and pump activation.
Don't use more than a little alcohol as the pump seals don't like it. I use distilled water for pump longevity.
Adam Auerbach
Sy #2419
Sy#26
Per Richard Lamb @ Aquamist, 50/50 methanol/water is ok in the system. Been using that mix for over a year w/o any probs. He warns that *methanol* only be used; hardware store denatured alcolol is ethanol w/ some hydrocarbon additives that *can* damage the seals. Seals eventually swell up & restrict flow.
