ARAutosports ATR downpipe
G
Guest
Guest
I have just received Mike's new downpipe for ATR headers. (nice pieces after some grinding and cleanup) My concern is over where to put the 02 and EGT bungs? There are non installed, and last time I guessed over something like this while on an engine stand........ well, it was unusable when the motor was installed. :oops:
Anyone have one of Mikes downpipes for ATR headers and pics with 02 bung installed with motor in the vehicle? TIA,
heavy breather
FBI enforcer
I've got an ATR DP that might work. Its packaged pretty poorly, but it should only take a few days to get it out there. :lol:
G
Guest
Guest
:fist:
U got the damn thing didn't you? :D So what if it took you three days to get the package open!
heavy breather
FBI enforcer
Oh, yeah I got it. Its in my basement. Laying next to a brand new turbo, external wastegate, A2A kit, 50#er's, etc etc. Now, if I could thaw out the bottom of the garage door enough to get it open, I might be able to get it under the hood.
Oh yeah, I also have a propane kit, and an ultimate to be dropped of by the big brown truck on Monday. Hopefully I can squeeze off a 14 or two next spring :wink:
WHenever I have friends over I get :shocked!: "You have only had that truck 3 months and your going to tear it apart and do what???"
Is there any prescription to cure this mental deformity?
Btw the fiance wont even speak to me anymore. The last words I heard were "What do you mean you spent $3k on that damn truck, I thought that was a down payment for my new Tahoe!?!?!?"
ed hess
race or get outta the way
is this the setup that pte sells that mike just did a 1399 special on for any size from te44 to pte60?
If is im gonna be upset cuz i thought the o2 sensor bung would have been preinstalled since the kit is for a sy?
tell me I have nothing to worry about and i dont have to weld anyhing on my new turbo and down pipe setup.
know i just remember i didn not tell mike i would be using his setup with new atr headers.
Sure hope i didnt make a mistake, that i will find when it all wont go together this winter.
Hey mike Am i OK?
ed
smeagol
No Roland has a custom setup. The PTE downpipe has an 02 sensor bung in approximately the same location as stock, a few inches (5-7" I'd say) after the turbo output, where I'd put one in Roland's case as well.
G
Guest
Guest
The PTE style should be ok, this is an ATR downpipe replacement (external wastegate on the downpipe), but should give better access to the passenger side plugs.
Having the bungs installed isn't a biggy in my case, just curious as to "where" to install them. There's a big difference with a motor sittin on a stand assembled, and suddenly wrapped by fenders, tires, radiator and hoses. I just wanted to insure I can get at it "both" ways :wink:
ghettosled
SYTY SUPERSTORE
Whoops.. completely forgot about the 02 sensor. It should have been there. If you dont want to send it back for me to install, then weld it just where the atr setup or stock 02 was.. about 3 inches behind turbine outlet. You can install the EGT bung right around there as well. i will include the bung when I send the clamp to you.
As for ed, the pte setup is complete with 02 bung. I have only got one downpipe where pte forgot to install it, but i think it was one of the first ones they sold.
G
Guest
Guest
No need Mike, I just got back from picking one up, should have it welded in this afternoon. Thanks tho
