areomotive fuel pump E85
A few things. What HP level do 60# injectors support on pump?
Converting to E85. What is the largest high impedance injector out there? I think the largest are the 84# if Im not mistaken. Someone correct me if Im not right.
The BTU conversion of pump gas to E85 is 28%. So 28% more E85 to match pump gas.
So switching from 60# injectors to 84# is also 28%.
Next moving from a 255 Walbro to the new Aeromotive 340 is 25% more fuel.
Looks like a winner to me. its almost a perfect conversion to switch from one to the other using the combos listed.
Next question. Does the Aeromotive 340 need a booster?
http://www.hoodtuned.com/store/index.php?route=product/product&path=20_26&product_id=150
e95 Ty
Re: areomotive fuel pump E85
This subject has been talked about on here recently....depending on how much hp your planning on making, the Aeromotive 340 may not be enough. Stock feed line, return line, fuel rails, regulator, injectors, pump, etc all need to be looked at when going e85. Its not just the size of the system either....all those parts need to be alcohol safe. Paper element filters also do not work with alcohol. I have been running on e98 now for quite some time with no trouble, but I learned a lot in the process.
i have to 255 walboro in tank that you mite be interested i'm going to e85 but i'll be making to much power for those 2/ 255. so i mite be interested in selling them let me know call me at 305-525-5865 or text me. i think that it would be your safe way to go.:tup::tup:what power you want to make?
MIXEDBREED
I am going with the 20g aero baffled tank with the a1000 pump mounted in the bed. Makes it easier to service and check lines ect.
I was thinking that setup would take me to around 550 to 600 hp at the motor. I have two walbros already I just need to buy a kit to get them to work. Im thinking the aeromotive pump might work by itself for my needs. Maybe I should just give campbell auto a call.
e95 Ty
For 600hp on e85 the aeromotive 340 wont be big enough....Went through this with Nolan last year. I was going to use 2 of them, but went overkill with a eliminator pump instead. Your always better off going a little bigger than you think you will need. I wanted to make 600hp at first, ended up with 725+ and could push it quite a bit more if needed. Nolan also had me go with 120lb injectors. Hope this helps.
Beavis
Still plays with trucks
I think alex had 120#'s and was at there limits......
MIXEDBREED
Anyone know or have a link to how the driver mods are done to run the 120# injectors?
Not sure if you can or do you have to run a standalone. Was planning to just get a custom multi chip from campbell but not sure if that will work. I searched.
