I know this post is a few days old.... I had a discussion with ARP about the difference and cost between #133-3701 v-Six bolt kit @ $130 and the #134-3701 SB v-8 kit @ $70.
The only difference (other than the extra center cyclinder bolts for the SB) is the short exterior head bolts are 120 thousandths shorter in the v-6 kit. This bolt is a special length and is not massed produced like the v8 kit bolts, thus the extra charge on the v-6 kit. :wink: 20 thousandth doesn't seem to be much of a difference but obviously there is a concern with bottoming out on the stock blocks. The bowtie blocks I believe have a deeper tap.
Last year, when I built my motor I had already purchased the V-8 kit. I then got concern when someone told me that there were differences in the kits. Before I put my heads on I checked the depth of the taps and had plenty of room. I used the v-8 kit and have had no problems. I am running the bowtie block and have not checked the depth in our stock block.
It just falls in the same line that our trucks and the 4.3motor is not the most popular or massed produced vechiles /motors and it cost us everwhere. But we expect that and wouldn't trade our trucks for anything else.
After the ARP discussion my speed shop guys were thinking that maybe the shorter bolts came about because of the circle track guys cutting the decks, etc and that they were porbably the first to have ARP but together the bolt kit. But that didn't make sense as there are separate kits for the brodix, 18 degree and other heads. Also, if that were true then the v-8 kit would have the same problem with that bolt length when cutting decks.
At the end of the day.....ARP's the best. Check your clearances and use either kit that works for you. Or the stud kit... 8)
John
