assistance please, new owner here
lightspeed240
truck it!
Guys, this is long, but Im a newbie, so please bare with me here, as I have a bunch of issues...
I just bought what I thought was the perfect syclone. The truck was one-owner, 14k miles, absolutely perfect (cosmetically anyway) and almost stock. The original tires are even in like-new condition. It was a dream come-true, so I thought. The owner said the truck had never seen rain before, and by the looks of it, I believed it. Anyway, here is what Im hoping someone can help with.
The truck had supposedly been in storage for the past 5 years on and off, but driven occasionally. Unfortunately, I didnt have time to secure shipping, so I had to drive it home 700 miles that night (the owner had 3 offers at the same time, so I didnt have time.) Anyway, by the time I got it home, I had quite an array of issues that I am now dealing with. Im hoping to get some feedback on how common these are, and some advice on what a few could be.
minor (mostly storage related, im sure:)
leaking trans pan gasket
leaking heater core (not bad yet, and I understand this is common)
leaking rear main seal
major:
truck misses/ticks constantly at idle
temp guage never gets over the first mark on gauge
truck only make 11 psi most of the time, builds slowly, but will occasionally spike to 20 (more on that later)
truck failed emissions with stock cat (more on that later also)
one front CV axle boot torn and bone dry joint...maybe damaged, but not ticking yet
The obvious mods on the truck are: manual boost controller, a KB ram air, battery reloc to front fender (odd as hell, I thought,) ATR big pump/heat exchanger, and a borla cat-back. It looks like is has an aftermarket DP, but it looks 2 3/4" and has an internal wastegate still. It has a manual VDO boost and FP gauge, which is how I read boost.
When I got it home I checked the thermostat to see if it was maybe stuck open, causing it to run cold and get stuck in open-loop/warmup. It turned out to have a 160 powerstat in it. I also looked at the chip, and it turned out to be an ATR "138A strip" chip (luckily I didnt run it hard coming home on pump gas.) I thought this would explain the idle, erradic boost on pump gas, failed emissions and engine temp, so I replaced the thermostat with a 180 and put a new, stock chip/memcal in it. I also took off the boost controller, to make sure it wasnt leaking or anything.
Nothing much changed, except the temp gauge went up just a hair (still barely over the first tick mark,) and the rev limiter comes in lower. It still idles poorly, and it wont make over 11 psi of boost most of the time (less in 1st and 2nd.) Occasionally, it will jump up to 15 psi for a second (with the ATR and boost controller on it, it it jumped to 20, which makes sense.)
Whew, all that. Now for my questions:
How common are heater cores leaking (very annoying to smell coolant in a perfect, beautiful 14k mile interior.)
Has anyone heard of relocating a race-cell battery to the front bumper?
Any idea on the idle miss? Ill be changing the plugs this week, BTW. Im hoping that is it.
Is it normal for the temp to go only to the first hash mark on the gauge with a 180 tstat?
Finally, and most importantly.. What is up with this boost problem? Does this ring any bells to someone? Im thinking maybe the coolant temp sensor is bad and causing the computer to stay in warm up or open-loop. Or bad MAP?
Any help would be greatly appreciated.
Oh yeah, once I get this running right, does anyone want to buy a perfect syclone LOL
leroy
Re: assistance please, new owner here
Heater core failures are common. There is a "how to repair" somewhere on the web. Search here for the link.
There are lots of options for battery relocation. ATR made a kit to relocate it in front of the front passenger tire. Smaller batteries have been mounted just below the stock location or along the frame rail.
A rough idle is normal. Injector ticking at idle is normal. A tuneup would still be good. It might be good to change the wires, cap, and rotor while you are at it. Search here for the appropriate parts.
The temperature gauge reading varies between trucks. There are 2 coolant temperature sensors. One goes to the gauge, the other to the computer.
It's probably good to replace hoses to the wastegate solenoid. Original hoses develop small cracks over time. The service manual has a procedure for solving overboost problems. Check here: http://syty.org/old/d&e-code31.html
Gutted catalytic converter could cause overboost.
A scantool and the service manual will help you out. Search here for everything else.
HTH,
Jim
and you mentioend it had a manual boost controller.
Slow down tiger, I had a hard time reading and following your issues. Lets attack 1 at a time.
I suggest remove the manual boost controller, unplug all vacuum lines to the wastegate actuator and run base boost (should be about 6psi) until you get your other issues solved. 20psi on a motor not in tune will be death.
#2 suggestion is to get yourself a scan tool, laptop combination. Searching here will round up lots of suggestions and ways people are doing it.
Then lets go for one issue at a time here.
lightspeed240
truck it!
Thanks guys, ill back up a bit here and slow it down LOL Its just that ive wanted one of the things for so long, and its killing me that it has so many little annoyances right now.
I apologize if I wasnt clear. I did remove the boost controller when I put the stock chip in it. I definately wanted to get it back to baseline as much as possible. I didnt pull/cap the hose. Ill try that. Im thinking that maybe, since the truck had an ATR chip in it, and I heard that the ATR uses the wastegate rod to adjust boost, maybe that was "tweaked" before, causing an issue. I hope, anyway.
What do you guys think about a temp issue causing this? Could a faulty coolant temp sensor for the ECU cause it to read low and maybe cause the computer to stay in warm up or something? I read somewhere that the ECU wont allow full boost until it sees over 140 degress or something. Is this realistic?
Leroy, Im thinking it might have some modified reolcation kit. Its got some type of access panel inside the front wheelwell, but the battery itself is a tiny little race-cell that sits up inside the bumper pretty much, like on a support member. Its nothing I have seen before. The bad part is that there is no remote jumper points, so if the battery dies, im screwed. Im going to add jump points asap.
Unfortunately, the idle is not just rough..it misses constantly. Not once per revolution, but its very noticable. I hope its plugs.
I took it to a shop to get it scanned, which should be done today, so hopefully this will solve a lot of it.
I hope the cat isnt gutted, because I hear these are expensive. I saw a receipt in the records that they owner bought an ATR 3" cat, but It looks stock to me. I imagine it got sold before I bought the truck. Im pretty sure it has a functioning cat of some type, due to the exhaust smell.
BTW, right after I got the truck, the tiny pressure hose going to the MAP sensor blew out of the rubber connector at the nipple at the plenum. I stuck it back in and clamped it with a wiretie. Im hoping this isnt common, because it really sucks when it goes into limp-home LOL Is there a better recommended solution to this? Does anyone make better hose kits, or should I just re-run regular 1/8 size tubing? Its not as nice looking, but its more reliable probably. I did that on my 944 turbo when the factory pre-cut hard hoses started breaking.
Thanks again.
Taking your truck to someone else (a normal shop) is a waste of time.
You will get no where except lots of bills, and an empty wallet.
I bet the amount you spend just getting truck scanned, giving you no useful data would have bought a scan tool for yourself.
The factory plastic vacuum lines need to be replaced ASAP. This can be a cause of a lot of your problems also.
The miss, sounds like ignition. Now the task for you as a new owner is to search and figure out what plugs work and don't work. Seach can be your friend. Hint most stores don't carry what you need either.
You might want to call up a site sponsor Tucker autoparts, let him send you a complete syty tuneup kit. He owns a sy or three, and knows what they need.
lightspeed240
truck it!
I agree about the shop. This place specialized in GM high-performance vehicles, and they have worked with several high-HP trucks in the area. Im hoping they are as good as they say. I do want to get a scan tool, so Ill probably look around online and get one. I definately didnt want to take it to a normal GMC shop.
Ill replace the hoses this weekend hopefully.
Ive heard the stock plugs are good for stock or mild trucks. Ill probably put a new set of those in this week also. Wow, they sure seem to be a bitch to get out of there though LOL
