ATR Aux IC plumbing
I have a ATR Aux IC. I have the cooler, brackets and pump (no hoses) but I plan on using my Jabsco pump. The ATR AUx IC has 5/8" Inlet and outlet while the rest of my IC system is 3/4" Where can I buy 5/8" to 3/4" adapter?
I plan to run my CCHE/IC pump to the Aux IC then to my upper IC and then let gavity drain every back down to the CCHE. Is my thinking correct?
Daron
Re: ATR Aux IC plumbing
Experiment and see which way moves more in your application, but I let gravity do its work on both ends, like the stock system is set up. Can be a bit of a challenge to bleed the air from , but this approach flowed more that the alternatives.
As for the 5/8 to 3/4 thing, get a small bit of 5/8 hose, slide it over the barbs and cut it off even with the end of the cooler barb, then slip your 3/4 over both and tighten with a clamp.
steve-o
Daron said:
....... but this approach flowed more that the alternatives.
i'm not one who frequently asks dumbass questions, but sometimes a few eventually slip out.....
How can the flow characteristics of our IC system be tested?
i know that fewer bends in the pipe system is better for flow, but how can doing something as simple as reversing the flow of water, in this case, get us better results?
lastly, if the IC pump is located lower than the highest water/coolant point in the system (i.e., the stock location), won't gravity always feed the pump regardless of which direction it is pumping the system?
Daron
Some contend that if you push from the output of the pump, thru the bottom barb on the cche, up to the bottom of the CAC and then run the top of the CAC down to the input of the pump, that it flows better. I tried many different versions, settling on the stock style routing with only one 90 degree bend at the input of the Jabsco..
