ATR downpipe information needed
Flyin Ryan
hated cuz he drives fords
Trying to figure out what to do with one I have on a truck. Not sure what type of turbo would bolt up to it. I believe it has a te44 on it now but haven't pulled it yet to confirm. Either way im replacing with stock dp and turbo on the truck. Not sure if it's worth keeping packed away to toss on my syclone becuase I don't know what it'll fit turbo wise or if it's worth anything since they seem kind of rare and I dont' see too many people running them. Any info/thoughts would be appreciated.
Icarus-54
Donating Old Member
Re: ATR downpipe information needed
PTE turbos will bolt up with some massaging of the bolt holes
The Atr turbos have 3-4 bolt adapter to use the GN exhaust housings. For simplicity of install you can use GN 3 bolt turbo's.
Flyin Ryan
I know what adapter your talking about Dave and this turbo doesn't have it.. once we get a wheel lock and can pull the rim/fenderwell i'll take pics and post them up to see if someone can id the turbo
I wonder if someone took a pte SyTy housing and massaged it to work with Atr DP.
canadian
sy in progress
Check around the outlet of the turbo and see if there's anything engraved on it.
jpalmer
I had an atr and my pte turbo bolted to it. Looked just like yours, well from the top side. Same gate too
Syclone22
Hi Ryan i got the same set ATR downpipe that i used
with the GN buick 3 bolt turbine housing that bolts on
a 3 to 4 bolt adapter i got some of these turbine housing
if you need one to build a turbo !!!
