ATR DP for 550 Hp build.
Injected1
I am having a problem with the final parts of my build. I think I need to run a 50mm wastegate for the build but the Dp is the 2 bolt flange style. What are my options as far as getting the WG hooked up. I realize that for the BOV I am going to have to TIG an aluminium V-band on the IC piping but what about the WG. Please help, I am ready to drive the thing.
Thanks
Re: ATR DP for 550 Hp build.
What turbo you running? I'm running an old atr 38mm with a 76mm turbo on mine. And I make(well made) 650-70 awhp and it works fine.
Try Me
I believe my downpipe was the same setup (before I modified it :tup: ) and Ive never had problems with it keeping up with the ATR wastegate.
Injected1
Really, that is awesome. I will get a synapse 40mm. I really like the synapse with no diaphragm. What head gaskets are you big HP guys running?
Injected1
Did you install them dry or with copper spray? Any problems with them? How much boost/hp?
