AJ
For those that have this regulator..., my questions are this...,
1) Clock wise turn is increase in FP, while couter clock is decrease?
2)What is the base fuel presure number. You get this with vac hose pulled off regulator?
3) If you seem to be running a lot of boost, do you increase or decrease the regulator?
4) If someone has a link, or cares to explain the proper procedure for setting the FPR to it's correct PSI, I would be appreciative.
Thanks
AJ
Thanks
AJ
