ATR Pitbull Chip............Anygod??
It's just a six
Super Member
Re: ATR Pitbull Chip............Anygod??
I ran the best time w/a ATR pitbull chip 12.29 @108 Stock turbo, trans, converter and so on.. Have not been able to beat it yet w/another chip. I would kinda have to quess on how much it improved my Sy,[ I did a couple other things along w/the chip change] but I would have to say @ least 1-1.5 seconds in the 1/4. I really think it is a good chip, it has knock retard built into it to save your engine. I also tried the KB street chip.. it was slower.. tried a couple custom chips from Sean & was slower.
They were all slower than the Pitbull chip. Now of course, I did not take the time to fine tune the engine with all the other chips as I did w/the Pitbull. Keep that in mind... :tup:
I would get one again if you can get one @ a good price. :2cents:
What made my Sy M.P.H. really good was changing to a better fuel pump.
Goodluck!
NecroWolf
lost marbles member
i really wanna know how you ran that fast with a pitbull chip? i got a pitbull chip in ty and i like it well enough for a two bar chip. now of course my pitbull is a street chip.
JAY
HotRodV6 said:
I was wanting to find out if the ATR chip is any good, from somepeople that have had it or currently have it, did it really help alot of not much?
Thanks
I like mine. Definately better in the 1/4, dont know 0-60 and no 1,2,3 full throttle is a plus. I noticed as bit better idle but it seemed to be a touch rich at lower rpm. The price was extremely good. I only paid $80 for mine. I think if you want more go to a custom chip or Ultimate & 3 bar map. But that's more money :(.
It's just a six
Super Member
You need a two bar map sensor for the pitbull.Mine was going to 18 psi boost pressure & the A/F ratio was right on.
As far as mods go, I had Pitbull chip, ATR air intake set up, port matched the turbo to exhaust manifold, HP 255 intank fuel pump, intercooler water lines plumbed into my heater core, wastegate rod one turn tighter[shorter] than stock, 2 degrees advanced on the timeing, MSD 6A box, almost 0 toe in, 160 thermostat, water wetter,ATR aux cooler kit,adj, afpr, 3 inch catback, Gibson type straight through muffler,I think that was about it.I have never run race leaded fuel. I have run 100 unleaded though.O yeah.. I raised the fuel pressure to 45-50?? Can't remember exactly. :tup:
jbone
[/QUOTE
What did you run in the 1/4 mile?
Im not that fond of my pitbull chip. I didnt notice any real gains with it but who knows. I just think its limited in its abilities as compared to a custom chip or something like the ultimate with which you can change your boost levels, and dif settings but thats just my opinion.
It's just a six
Super Member
I ran a 12.29 @108 Then I ran a 12.31 back to back.
How slow is still slow? :(
jbone
14.2 :cry:
SY2932
Administrator
Here is a link to compare some of the aftermarket chips. Bottom line is if your truck is not running 100%, just adding a chip isn't going to make it run any better. This is DEFINATELY the case with the Ultimate chip and required 3 bar MAP sensor. Many folks have installed it in a poorly running truck and it ran much worse, if at all.
Flyin Ryan
hated cuz he drives fords
ATR Pitbull chip is a 2bar chip like stock meaning it simply can't see anything over 14.7psi.. that means 15psi, 25psi and everything in between look the same to the chip. There isn't any way to adjust fueling for anything beyond the stock 14.7psi since it can't properly read any of those.. Im sure if you reburn over it you can but that would be a custom chip then right.
Also the Pitbull uses open loop boost control. So it just tells your wastegate to go to x % of DC. You then adjust the wastegate arm to get that x % to match up with your desired boost level. It know I read somewhere that it was made with 16psi in mind even though it's a two bar chip.. so it's just coded to run a little richer.
Other than that, it has some minor tweaks, like limits removed and turn-on temps lowered and stuff. It's generally concidered one of the better and safer of the stockish 2bar chips. Of course im referring to the 137 version which I've used in my truck for at least two years and have had no problems except a rich condition here and there which was resolved.
This site also has some info on Pitbulls I believe
http://www.syty.org/old/promguide.htmls
mmp142965
say it like you spell it!
I have the pitbull in my otherwise stock ty. im going to make a pass with it in and with the stock chip in about a month. (somone is kindly lending me a stock chip at the FAST meet coming up) I'll post the results for ya.
It's just a six
Super Member
14.2
__________________
That is kinda slow...What did it run with a stock chip?
Thanks :tup:
well cool, is there anyway to hack the ATR chip using tunerpro and an ostrich programmer to allow it to read a 3 bar map?? Of course i guess you cold copy the program to a new chip and then tweak on it somemore? Maybe fine tune it some.
Thanks for the info.
