ATR Pitbull Chip
Captain Morgan
Moderated User
Re: ATR Pitbull Chip
the ECM is located behind the passenger side dash, drop the 5 (7mm) screws that hold the black plastic cover in place. I think it might be easier is you remove the kick panel also on that side (4 phillips screws). You should see a goldish color bracket on the bottom lip of the dash held in by 1 screw, take that screw out and wiggle the ECM down and out.
With the ECM on the floorboard, locate the access panel, held on by 2 screws and sometimes a decal. Cut the decal and remove the screws, you will see another blue memcal in there. To either side of the memcal, you will 2 white tabs. Push those tabs outward from the memcal and the chip should release and pop up. Once loose, remove the memcal and put the Pitbull memcal in its place.
There is a notch on the bottom of memcal, make sure its facing the right way and that all the pins are lined up and firmly press the memcal in place pushing on the outer corners. You should hear/feel it snap into place when those white tabs fold back up.
Reverse the rest of the steps above (have fun getting the ECM back up in the right spot) and youre good to go.
93ty475
try this thread to find the ecm.... you don't have to solder anything....just remove and replace the chip...there's an orientation groove on one side of the chip....just make sure it's fully seated and snaps in place...I would make sure you have datamaster or a comparable realtime scantool to test the results of this atr chip....you might start knocking on the high end being the timing and who knows what else is turned up.....I'd recommend at least the basic supportive mods for this chip such as fuel pump and adj. fpr...
0966Sy
Code what?
I'll include some important things, dissconect the battery (-) before removing the ECM and or installing the chip. No reason to unplug the wiring harnesses attached to the ECM. Although dont be pulling on the ECM to get it out. Pulling out wires from a wiring harness connector will just lead to a head ache. It's nice to have a ground strap around your wrist when working with ECM's to avoid any electrical shock to the circuit board causing permanent damage. Just be sure to groung yourself to somthing before touching the ecm and you will be just fine. Rolling around on your back on the passenger side floor board will make for some static.
MAITAI1993
DON'T MAKE ME SLAP YOU.
I chimed in because im going to need this info but I dont have any scantools what are the proper steps to take in getting some software. Also if you have a stock chip you cant boost over 14.7 PSI right because I just got finished with my DP turbo swap and other things and now my boost is holding strong at 20 psi (my old solenoid lines where also bad all new now) I have never opend my ecm what does the stock chip look like are thay marked with things if they are aftermarket do you guys think I could already have an aftermarket chip if its boostin that high....
my buddy gave me a Kenny bell chip to try i have herd not such good things about this chip
NecroWolf
lost marbles member
i'm not impressed with my pitbullchip and i have heard very bad things about the kenne bell chip not having any knock retard and spark knock is the death of our engines
MAITAI1993
Same heard here thanks what do you guys think about the ult. chip
kwick6
Since you upgraded your turbo, an ultimate that is not custom tuned to your truck will not control boost.
You will be able to run over 15psi because it is a 3 bar cal , but you really need to get your truck checked out with datamaster before changing chips.
Most trucks have minor issues that need to be taken care of before changing the chip.
If you value your engine, you will not let boost go over 15psi on a stock chip. FWIW.
Tooky
Serious about performance
The Pitbull is a decent mild chip if you're really on a cheap budget at the moment but ANY chip requires Serious monitoring with a laptop datalogger software program like Datamaster. Be Especially careful with the Pitbull's boost control because it doesn't really "control" the boost so much as set the wastegate open about 25% and let your wastegate ROD do the real adjustment... and if the boost soars past 15 PSI, the Pitbull won't know or care..
On my truck the Ultimate's boost control was worse than the stock chip, and the Pitbull offered mighty fast spoolup and good control with a small spike. I ended up going to a manual controller (BoostValve.com) and it works like a champ.
