ATR Pitbull questions
Mad Mike
SYCOSIS
Since I get "DEBUG MODE" when trying the search function I'll ask instead.
Does the pitbull chip disable the knock readings by the ECM and overboost fuel cut off? Finally, put diacom on my typhoon and got 0 knock and 26 psi of boost. :eek: . No codes and trucks pulls great. First time I really got on it. Everything else looked great! O2 readings, shift points etc. Looks like I'll be pulling the chip and readjusting the wastegate rod. After tune up I'll be installing the Ultimate.
Flyin Ryan
hated cuz he drives fords
Mike, not too sure about the "chip disable the knock readings by the ECM" cause mine still shows knock with the chip in (2 to3) but in my experiance it does diable the overboost fuel cut. I tried the chip in while i was having over boost issues awhile back due to a few vacuum lines being cracked and the truck would over boost like you said in your post in the 20lb range and fuel would not cut.
Code:
Does the pitbull chip disable the knock readings by the ECM and overboost fuel cut off?[quote]
No to both[/quote]
Re: ATR Pitbull questions
No it doesn't touch the Knock Retard. I beleive it does remove th eoverboost fuel cut off. The boost control is set to open loop, (similar to the GN's) So the ECM isn't using feedback to control boost. That is why adjust the wastegate allow for more boost...
smeagol
What he said.
Check your datamaster to set for 2 bar mode...
Captain Morgan
Moderated User
What he said.
he said Diacom :lol:
