I raced about 2 months ago with my stock upper intercooler, rubber IC lines, Jabsco pump and stock lower heat exchanger with a Spal puller fan. Water and Redline Water Wetter filled the system. From the start line to the finish line IAT temps would rise 70 degrees on a 17psi run. Outside air temp was 70 degrees
Yesterday at the track outside air was 88 degrees. I replaced my stock intercooler with the leaking neck, with a used ATR upper intercooler, everything else was the same. From the start line to the finish line on the same psi IAT temps were only rising 50 degrees.
Not a dramatic decrease in temps, but I was happy, since I wanted to retain my stock-style intercooler system. Probably gave the Syclone 10 HP or so.
