ChevelleDude71
Lo Boost
I was looking at my truck today and I thought I would share what I have found out about the Battle bars. before I received the bars I had installed the beltech lowering springs and a 3" lowering block and the (3/8"?) setback plate. the truck was slammed. But I found that after I installed the battle bars with this drop I found that even with my 18's (one inch taller then the factory wheels) the battle bars were hanging too low. Now I know I have stated this before in my projects page but I thought I should post what is the MAXIMUM drop you can have on these trucks with 275/40/18's and not have to worry about dragging them in the event of a tire blowout. I have found this to be nerve racking for me to get that perfect stance, so to save you some time and the purchasing of every size lowering blocks :roll: here how I did it.
first off I had to cut off the bottom hole for the Battle bars ( trust me I didn't want to but it was the only way, and let me tell you that these things are thick)
Then I used the beltech springs, a alum 1" lowering block with the stock pinion wedge ( 1" ) and the 3/8 setback plate. (all bolted together)
Then the here is how it turns out.
another shot, can't wait to get that heavy motor in the front so I can get that ride height dialed in with the coil overs......
It's been months but I'm finally happy with it...
