Audible knock but no KR
92Ty#1524
Tweaked fuel pressure. Took it out for a WOT run and experienced audible knock near the top of second gear (12lbs boost, 4600 rpm, O2mv 980, LTerm cts 130, STerm 128 ). I took my foot out of it FAST.
Looked back at DM, knock count only went up by about 13....absolutely no spark retard.
Coincidently, I tapped the back of the block earlier today with a socket extension and observed my knock count jump in bursts of hundreds per tap. Kinda led me to believe that at least the sensor is working.
How is it that the sensor/circuit goes ape shit over a tap but does nothing when the motor tries to self destruct?
myclone
Knock sensor ever been out/replaced? If so it might have been installed too loose or too tight which could have, theoreticly changed its sensativity to where it would pick up the block tap vibes but not detonation.
I think they are supposed to be torqued to 8 inch lbs or poss 8 ft lbs (dont quote me as that may be completely wrong).
Just a thought.
92Ty#1524
Yes. It had been replaced. I dont recall torquing to any spec, though. Suppose I should look into that, eh?
Thanx for the suggestion.
