Autolite Fuel PSI Gauge
tbauer03
TRBOBOX
I have an electronic Fuel Pressure gauge which I had hooked up to the fuel rail. I have since used that sender unit to connect my Holley Dominator.
I was curious if I could just tap into the 3 wires off of the sender and correctly power both gauges? if not I can setup an output from the dominator, but I'd prefer to save outputs if possible to avoid buying another wiring harness for the dominator.
Thanks
