Autometer water gauge sending unit???
bender
I got a new gauge and searched around a bit for where to put it. Is drilling the lower intake pretty much the only option? I dont really care if the factory gauge doesnt work anymore as it pretty much just sits in the middle anyhow. Can I pull the factory sending unit from the side of the block and replace it, and if so, how much coolant is going to come rushing out of that hole when I pull it.
warmpancakes
Re: Autometer water gauge sending unit???
water temp I assume? if so theres a unused port in the head and one in the water pump
bender
Yes water temp. When I bought the truck it came with a new water pump which I assume is a standard 350 sbc pump rather than the syty pump, because it doesnt have that port like my stocker did. Is the unused head port the one in the passenger side head? It probably is since it doesnt look at all easy to get too.
warmpancakes
If your pump doesn't have the port youhave the wrong pump it's not a reverse rotation
13Pelle
That means my pump is wrong too then....I don't have the extra port on mine either. :(
Windedv6
Ty n 10s
You can replace the one on the drivers side head if you don't care if the stock gauge doesn't work. It's function is only for the stock gauge. I was told that the stock sensor in the head uses the same 0-5 voltage as would the auto meter sensor. You could just tap into the sensor lead in the harness and check it. I have not tried it personally, but have thought about putting a water temp gauge in my AWD Ty and would try that first.
And yes you would bleed a lot of water out if you took out the stock sensor in the head. You can drain the raditor down to a level below the sensor and then you won't have the mess.
John
bender
John
Im going to get some color matched paint for the pillar tomorrow and try using the stock sender. I can verify temp with datamaster to see if it right.
