Autoprom how to
Ian Turgeon
Cascading Inspiration
Ok I had a few minutes to play around and I'm slowly getting this.
I had no problem burning a chip, truck runs fine on it ( just burned the same chip I was already using)
Now getting tunerPro RT and the autoprom to behave is a different story.
I figured out to get ALDL data through in Autoprom mode i guess, make sure no chip is in the zif, horizontal switch to the left and vertical switch in the center.
I can rarely connect, (have to keep hitting f4 and connect and close window) and when it does its all errors.
Just need to verify the vertical switch position, and see how everyone else is getting this to work.
And Ill give emulation a try after that.
Another question, can you send a bin to the autoprom and disconnect it from the laptop?
I havnt tried ALDL pass-through mode yet... I'll have to give it a try soon.
Re: Autoprom how to
The silence command is key to connect on our trucks.
Paul is better one to ask, but I think that is the bug currently with software and autoprom is connecting when NOT in pass through mode.
Yes, you can disconnect laptop.
skwayb
NWSTP
Re: Autoprom how to
I have a question.. when you upload a bin, do you have to have the key on for it to upload and verify? Or can you do it with the Key off. (You should be able to do it with the key off but on mine I have to have the key on or it always fails to verify.)
Here are some of the answers to your questions:
1) Never leave a chip in the AutoProm. The Zif socket on it is for reading/writing chips. That is all. Leaving a chip in it could damage the autoprom when you are trying to emulate. Never had it happen but that is what Craig told me.
2) Make sure you have the newest version of 4.0. Some connection issues have been due to a bug in a version he put out. But this isn't our case. Our ECM is a pain to connect to.
3) Once you upload a BIN to the Autoprom, you don't need to have the laptop connected anymore unless you want to make changes to the bin during emulation.
4) I have never been able to get the ALDL connection to work when the Horizontal switch is in Autoprom mode. Surprised you could connect and get the errors. I never could. Try sending the ECM Silence command a bunch of times until you see the error count stop climbing. If that works then you should start to see ALDL data. You are then golden to Emulate and see ALDL data at the same time. At this point let the tuning commence.
But I have only been able to get Tuner Pro to connect when the Horizontal switch is in ALDL passthru. (Datamaster works in this mode too) I set the Interface to Max232 connection, the approriate COM Port and then follow the same procedure of sending the ECM silence command until the error count stops. But at this point you can only see ALDL data and not emulate. This is the bug that our ECM has in Tuner Pro. Mark is aware of the problem. I have been bugging him for a while about it. (a Year lol). Maybe if more people bug him, he will get it working soon. I know you posted on his forum but maybe others could if they have the Autoprom.
5) Unit Mark fixes the problem, if you desperately need to Emulate and log at the same time, then get yourself a Serial ALDL cable like you would use with Datamaster. Leave the Autoprom switch in Autoprom mode, but go into the preferences and set the interface for the ALDL to Max232 and the appropriate COM port for your serial cable. You should then be emulate and see aldl data in realtime. You will still have to use the ECM silence command to get the errors to stop in Tuner Pro. It works but not as elegant as the one cable connection to the Autoprom.
6) Here is an explaination of the switches off of the Moates FAQ. He explains it better and I didn't want to have to type it out.
What does the vertical switch on the back of the Autoprom do?
The vertical switch on the backplane of the AutoProm changes the resistance between pins A and B on the ALDL interface cable. The topmost position places 10k ohms between the pins. Some ECMs require this 10k resistance in order to connect to the ALDL datastream (1227165 is an example). The middle position opens the connection between A and B (infinite resistence). This is the "default" position. Most cars can be datalogged in this position. Cars that require 10k to connect can be switched to this position after connection. The bottom most position shorts the connection (0 ohms). Most GM ECMs dump trouble codes when pins A and B are shorted. This switch position makes doing so simple and convenient when a PC is not available.
What does the horizontal switch on the back of the Autoprom do?
The horizontal switch, called the bypass switch, switches whether the PC communicates with the AutoProm CPU or directly to the ALDL interface hardware. When the switch is towards the serial or USB port, the PC communicates with the AutoProm CPU. This mode is used for changing data in the emulation buffer, for acquiring A/D data, and for ALDL datalogging in "AutoProm" mode (TunerPro only). When the switch is switched away from the serial or USB port, the AutoProm is in bypass mode. This mode allows the PC to communicate directly with the car through the ALDL cable. This allows the AutoProm to function as a simple ALDL cable. Use this mode to communicate with your OBDI vehicle using most ALDL data acquisition software such as WinALDL, CarBytes, Datamaster, etc.
Let me know if you have any other questions. I'll help best I can.
Ian Turgeon
Re: Autoprom how to
Good info Paul. I updated to the latest build last night hopefully we'll see some changes. I installed Datamaster as well in order to try and get the pass-through mode tested.
( I'm drawing notes and diagrams on the lid of the box I'm keeping the autoprom in)
I was able to send a bin to the emulator with it sitting on my desk, so I think I'll be able to do it even with the key is off when its in the truck.. hope so anyway. This may be a feature that applies to the USB version (speculation : usb version is maybe able to provide the power required to do this via the usb where the serial version requires the power from the ecm)
I've gone through moates and mark's documents several times. I understand what the vertical switch does but I dont know what mode we require (top or middle)?
Hood will have one soon as well, we'll get him to drop a line to mark about getting connection to work with our ecms. Would it help if Mark had a 749 if he doesnt?
Ian Turgeon
Re: Autoprom how to
From the Turbo_P4_Doc
Section 5.4 Message Type
Resistance to Power Ground
Greater Than 20K : Normal mode
10K : ALDL Mode
3.9K : ECM Factory Test
less than 500 ohms : Diagnostics / Field Service
Ok in Diacom I always had to set it to normal mode, so Im guessing we need > 20k ohms to datalog.
Does that equate the middle setting on the vertical switch?
Re: Autoprom how to
We hooked mark up with a 749 ecm and ecm test bench. :)
I am sure it will get fixed eventually, he just has a lot of other foundation stuff to finish up.
skwayb
NWSTP
Re: Autoprom how to
Ian I was able to send a chip to it on my desk also without a problem. It was once I installed the adapter in the ECM and ran the cable to the autoprom that it wouldn't work until I had the key on. It would just fail everytime with the key off.
For the switch...Just put it in the middle and you should be a datalog no problem... infact I never have put it on anything other than the middle setting and I never change any setting in datamaster except the COM port. That is it. I only change the horizontal switch to go from AutoProm mode to ALDL passthru.
Here is Craigs quote on the position of the middle switch. "The middle position opens the connection between A and B (infinite resistence). This is the "default" position. Most cars can be datalogged in this position." - Craig
And like Jeff said, I already hooked up Mark with an ECM test bench and my old 749 ecm. So he is gtg there. Just needs to make a cable to connect to the 749 to the ecm test bench. He is more of a 730 guy and has one of those all hooked up for development. Before he would have to sit in his Trans Am with his laptop to program. We sat in my Ty when he was trying to get the connection issue fixed.. What a Pain in the ass.
Let me know if the bin upload works when the Autoprom is in your ty without the key on. Might be an electrical problem in my Ty...
Ian Turgeon
Re: Autoprom how to
ok got to play with it again a bit
Emulating works, i messed with the idle rpm a bit and it worked, can easily update tables and values pretty quickly. Even flashed the whole bin at idle, hickuped but didnt even stop running.
I was able to get datamaster to log in pass through mode once I set the usb driver to com2 where dm could find it ok. I also got tunerpro to datalog (its too late for me to remember for sure if I did it in autoprom mode or passthrough) but I think it was on pass-through mode.
Oh, and no, once I have the autoprom wired into the ecm, I cannot upload a bin correctly to the thing, it wont verify. So key on when its plugged in.
Gotta get tunerpro to pick up the ALDL through the autoprom... even more would like to be able to do both at the same time. No way Im hooking up a serial cable too, I bought this thing with the one wire pass through as a selling point.
If mark cant get it working I'll return this beast and go with the ostrich.
