AutoTune tuning question
BMFB
Not to scale
I tried to post this on the code 59 forum, but i might get an answer faster here...
Ok, im running code59, i think im using pauls stock bin on my stock truck. But, i was wondering if... when im logging data, and inputting it to my autotune sheet, should it be all of the data? or should i have it so its only using stuff from when im cruising/accelerating and not decel, ect. This is my first day doing it, and its coming out a bit...jagged. also, on my 3d graph, you guys have it oriented so that you can see the rise in the curve, where as mine kind of starts on the left and is mostly occluded by the rest of the chart, any advice?
Daryl H
Re: AutoTune tuning question
Yes it will be jagged.
You will have to constantly smooth out most of the issues so the fuel curve is not the Rocky Mountains. There is a small delay in what your truck wants, what your engine is doing, and what your ECM/computer is logging. Take that into account.
Having said that, I do have the St Louis arch in my table...but that is how my truck likes it.
I believe if you hit CTRL and ALT with your mouse you will be able to re-orientate the graph.
If you hit CTRL and the mouse the graph will get bigger or smaller.
I may have those mixed up a bit.
