Auxiliary Heat Exchanger Question
syclone 1092
SyTy.net Pea Shooter
I've already purchased a upgraded ic pump from Ron Gregory and would like to piece together a auxiliary heat exchanger. Fluidyne has a ZR-1 air-to-oil cooler with dimensions of 23" x 12 1/4" x 1". Could this possibly work for this application?
Thanks
Mike
bdubb
I am teh kingpin!
just measure your area u have to work will. you will have to cut part of the radiator support off.
Lynn D. Brown
Aux. CAC
Aux. CAC
Mike,
I will try to do the same thing. So, how is everyone doing this ?
Going to the standard location under the car 1st, and then to the
one behind the radiator ? Then of course back to the Upper IC.
bdubb
I am teh kingpin!
Re: Aux. CAC
Re: Aux. CAC
Lynn D. Brown said:
Mike,
in front of the radiator. and i held mine up with zip ties.
