I'd thought that you had to be careful with running in series because of the added pressure needed to flow coolant through an extra series aux. cooler. It doesn't seem to me that it would matter if the flow were balanced between the two coolers; in the end, you are just adding more cooling capacity. As long as the aux. cooler was similar in restriction to the stock cooler (like a heater core, etc, and NOT like an oil cooler), where it is meant to pass coolant, the restriction would be relatively the same, and each would flow equally.
Like you say, with one cooler having more and one having less restriction to flow, the system will only flow as much as the most restrictive part will allow. With a parallel system, the stock IC will flow its normal way, and the aux will flow however it's designed to, in addition to the stock IC.
I can see the sense in a series setup, as one cooler drops the temp, then the second cooler drops it more, but I can also see the sense in a parallel setup, where you are in essence, making your stock I/C "larger", and adding more cooling capacity.
Maybe I was dropped on my head as a child...... :roll:
