warmpancakes said:whats the motor from that powersteering fill tube is weird?
DonHo32 said:The motor is from a 93 TY. All of the accessories are from my Vortec motor.
loubotzz77 said:how hard is it to yank theses motors i need to yank mine and rebuild it??
Bad Ass Black Trucks said:I like it. I went a little different route and put a V8 in my X-cab sonoma and bought a typhoon.
What tranny? I'm assuming no AWD. I like the C6 wheels. I was thinking about going with the same ones for my truck, I'm just having trouble finding street wheels for the narrowed 9" in the back with 5 X 4.5" bolt pattern. Doesn't work well with the corvette offset and 4.75" spacing.
Did you have current performance make you a new custom harness? How's it working for you?
UR50SLO said:I'd mentaly measured how close that newer compressor design/front accrys would fit with the Typhoon intake. Glad it works...!!
I think I'm going to update my wife's front accrys to (Hopefully) get the A/C to be cold! It just seems like the older compressors don't work very good and take alot of power to run. I think the newer compressors like you've got on there are better and they are designed for 134a.
Great setup!
I turbo'd our 98 Jimmy with old typhoon parts... Works great! Just need the Marine intake so I can use her stock (Typhoon) injectors.
Great job!
Scott~
UR50SLO said:That's neat! Putting it to the ground now there's a challange.
The Jimmy is working out nice. I just can't stand that factory injection setup for fueling.
It works ok now with 3/4 throttle but much more it's reading 100%duty cycle. And I'll watch the WB o2 go lean.
So up to about 8psi it's great.
2wd is great if you can use it!
Thanks for the info man!
~Scott
