92 Ty 1173
Ok, build goes, .30 over, L35's w/ 2.02/1.60 ported and polished, comp 422 cam, 20g turbo, stock injectors, AFPR set at 52psi, Walboro 255 pump and an ultimate for a stock truck. So while I'm driving it sputters every once in awhile but when I throttle it, from a low rpm it backfires and carries on, no matter what timing setting is on the ultimate. At a higher rpm it seems ok, goes like hell, even with little boost. I know the chip is for a stock truck but I was hoping it would run ok till I get it reburned or get my $59 stuff. Any ideas? BTW my boost is turned down to about 5psi cause I'm still breaking it in, got about 300 miles on it. I plan on picking some brains at the NASTE meet but thought I would get a head start, maybe have it running better till then. Thanks
