bad fuel pump? maybe something else not sure
Xtrempickup
All turbo All the time
i have a 91 syclone, its pretty much all stock and nothing i know of has been replaced or changed on it in relation to the fuel system. it has strong cranking, but no start. i havent looked into it much, im figuring either the fuel pump died or is weak or its something else in between. it acted up a few months ago as far as one day it wouldnt start, but a week later id turn the key and it would start right up. it did the same recently, i moved it in the afternoon but in the evening it wouldnt restart. tried starting it a few days later, still no start. not sure what to look at personally. if its a bad pump i am told il have no pressure at the fuel rail. it could be something bad or failing in relation to spark distribution if i have fuel. whats the easiest thing to check first? i know with other turbo cars its not necessarily a common suspected item that creates the problem. i hadnt had any issues with the truck but i do have all the tech manuals at least. any suggestions?
sytyguy
Moderated User
Re: bad fuel pump? maybe something else not sure
See if you have spark. If not, verify the ignition module and coil are healthy.
See if you have fuel. Take the vac line off the front of the upper intake and spray some starting fluid into it. If it cranks and dies, you have a lack of fuel.
More to do from there.....
Flyin Ryan
hated cuz he drives fords
Verify your getting spark first and verify the truck's getting fuel pressure.
When you turn the key to the on position before cranking, can you here the fuel pump prime?
