Re: Bad news
Well, where to start. I just finish installing my new downpipe that I had coated before installing.
Now on to the downpipe story. I have 2 of these downpipe made by the same person. The 1st one fit like a glove, but it wasn't coated and had the 2nd O2 bung (which is a no no in Calif :rant
. The 2nd one I had sent out to get coated before checking, that was a big problem, but I had base my decision to coat the 2nd one on the fact that the 1st one fit so well and the 2nd one only had 1- O2 bung in it which I needed for smog testing.
1. The one that I coated had to be cut apart because the 1st section hit the exhaust manifold at the very back cyl. Because of this it would not sit flush with the turbine housing. Which didn't really matter because the top mounting hole was off by .140 and the outside mounting hole was of by .120 as well. On the 1st downpipe, the mounting holes were drill really nice and on the 2nd one they look like a torch was used to cut them out which I did not notice until I had it coated because I never look at it. ( I think that it was the rough cut and the finishing work never got done on the flange :rant
2. The 2nd section had the wrong angle on it and would not even meet up with the 1st section. It required a new leading section be added after it split while trying to fix it. I had to replace the 1st 3" of the 2nd pipe. The final bend was off as well and I had to fix this too.
It was hard for me to believe that these 2 downpipes came from the same place. None the less I learned a very valuable lesson with this true story that I have share here with you.
