Bad O2 Sensor? - FIXED - Damn ribbon cable
Mad Mike
SYCOSIS
Took the syclone out for some testing. After the truck shifts into second (5100rpm) at WOT, the O2 volts are all ready low 890's- 910, knock begins at 3.2 and starts to climb, then as the rpm's increase the o2's fall. Truck shifts at 5100, rpm's fall to 4550 and start back rising but the O2 volts keeping dropping. At 4600 rpm's the o2's are 723, knock is 8.6. But even with my foot off the gas the O2's drop all the way to 97 and knock retard continues to climb. :eek: Spark advance was 15.2 during most of the test dropping to 14.5 at the highest knock retard.
I tried two runs with similar results.
Question. Is it a bad O2 sensor or something else?
With no other changes to my truck O2's were always 960-1000 AFR are 11.8-12.0 . No knock until after second gear and boost at around 15 psi. Very cool night, MAT's were 80-90's at the beginning of each test. Intercooler is working fine. FP set at 50 base.
Diacom file available for review.
**** After Don's post I removed my ashtray(Ultimate is installed there) to take a look at the cable running from the ashtray to the ECM. Sure enough the ribbon cable where a connector was placed was pinched by the movement of the ashtray. Just to make sure I fixed it , went for a few test blasts down Rt 295 early this sunday morning. Coming off the entrance ramp a newer caddy blows by in the middle lane. Tap the space bar on the laptop and punch it. In a matter of seconds I blow by him all the while I'm watching the knock retard. I seen 1 degree knock retard. That's it! The caddy catches up and passes and the guy is looking at me just shaking his head. ME, I had a smile from hear to hear. Graphed everything - knock retard one spike at 1.8 degrees with 18 lbs of boost, O2 947. Tested it on a couple of other settings just to be sure.
jwaller
Evil Genius/SyTy Guru
if goin lean indicated by the o2 and your getting knock. seems to me that you have a lean problem and the o2 is working correctly
how are the xcounts at idle? are they lazy or fast?
try bumpin up the fp some and see if it cures the leaness.
could be the extra cool night is giving you a but more air than it normally sees.
Mad Mike
SYCOSIS
You know I did bump up the FP. I had it set at 54, thinking that was the problem last time I was out. Outside temps were about 50-55.
o2 transit starts at 128 at idle, goes to 135 in 2 frames then to 137 in 5 1/2 frames.
Tooky
Serious about performance
Is your fuel pump dying or your fuel filter perhaps clogged? Can you verify fuel pressure remains acceptable even at the top of 3rd?
Tooky
You may also want to check the plugs, if it's really doing 700s, I would think the plugs would show it.
Tooky
Holy smokes!! With that datamaster shot I can say I am convinced its lean fueling, the O2 takes a total NOSE DIVE!! Right at the same time the knock starts, your knock is Beautiful before that, 0.0..
Mad Mike
SYCOSIS
Yeah, up until this point I rarely ever got knock . Sometimes a spike or two of 1.6-2.8 but that would be it. Now??????????
The other thing I noticed on the file is battery volts are 12.9-13.0 during the run where before they were 13.8 - 14.0. Dieing alternator effecting the fuel pump?
jwaller
that is possible too. but I woulnd't bet that is the whole problem. are your part throttle and idle volts good?
Mad Mike
SYCOSIS
At idle they are 13.7-13.8. Looks like 13.2 -13.4 part throttle.
Mad Mike
SYCOSIS
Today I was able to verify that the FP does climb with boost. Thanks to Ed Hess. Volts were around 14 without lights etc on. So what now? What's the next thing I can test?
Raist103
hey mike mine was doing this too, if you remember i thought it was the chip and even had ed let me use his at the track to test this. o2s would drop as i stepped into it more fine while cruiseing. mine would drop down to 50 or so from 980-1000 now ready? the chip was not set in all the way, then the next time it happened, the ultimate wire was was pinched. everything since then has been fine, i would try differant settings on the ultimate and play with the wire and make sure it is set into the ecm all the way. sounds dumb but it happened to me twice.
Mad Mike
SYCOSIS
Tooky - I'll pull a plug tomorrow and Don thanks for the tip as I was not even considering the chip. My ultimate is installed in the ashtray and I slide it in and out. Now I'm wondering if there is something with the cable. I'll pull the ashtray out tomorrow, check the cable check chip seating and test some more.
Mad Mike
SYCOSIS
**** After Don's post I removed my ashtray(Ultimate is installed there) to take a look at the cable running from the ashtray to the ECM. Sure enough the ribbon cable where a connector was placed was pinched by the movement of the ashtray. Just to make sure I fixed it , went for a few test blasts down Rt 295 early sunday morning. Coming off the entrance ramp a newer caddy blows by in the middle lane. Tap the space bar on the laptop and punch it. In a matter of seconds I blow by him all the while I'm watching the knock retard. I seen 1 degree knock retard. That's it! The caddy catches up and passes and the guy is looking at me just shaking his head. ME, I had a smile from hear to hear. Graphed everything - knock retard one spike at 1.8 degrees with 18 lbs of boost, O2 947. Tested it on a couple of other settings just to be sure.
_________________
Raist103
great now just let me know when you are going to the track next so i can watch and get some video
