Bad sound from turbo
NeedaSY
Go Ahead N Go
I acidentaly pulled off the vaccum line ontop of the turbo where that conector electrical plug is the line above that lil spungy breather and i drove like 200 yards and pulled over cause it was makin a hissing sound when the turbo spooled up i put it back on and the sound still hasnt gone away ??????????
QUICK STORM
B.A.M.F. BMW Tech
Re: Bad sound from turbo
did you put it on the right port? there are 3 ports and only 2 vacuum lines, 1 port is a vent
The port with the little clips is the one you leave open. You can search for some good photos to make sure you the other 2 on correct..
NeedaSY
Go Ahead N Go
well i am almost positive cause thers only one spot it came off of its the line that runs to the wastegate. could this mean now that i need to adjust my wastgate and im some how no overboosting. this doesnt make sence it sounds like someone is raking there nails across a chalk board when its spooling up??
