Sean Krupa
Moderator
Past couple weeks, I've had an interminttent problem with Starting the Ty. I usually always let the Fuel pump prime before I crank over the engine. When I start it, it starts and studders real bad, like it's Camming. This only happens sometimes, usually when the truck sits over night.
I checked the Fuel pressure with the truck running and when I shut it off, and fuel pressurizes instintely and holds pressure off. I can still hear the Pump prime when I turn the key. It took all week just to get this Video cause the problem happened today and I drove it all week. (The idle smoothed out a second after the video)
Maybe it's a Bad tank of Gas? I changed the Fuel filter 2 years ago, not many miles ago. The Walbro pump was installed in 2000 with about 50k miles. I know have 99k miles. Maybe it's getting weak now....
The Ty still supplies a ton of fuel for Boost and in the 10s-11s for AFRs under boost.
Thanks,
Thanks,
