bad wastegate diaphram?
Flyin Ryan
hated cuz he drives fords
Okey the syclone's had issues with boost and it's been on the back burner for a little while. Today I yanked the wastegate actuator off the turbo and put it in a bucket of water.. applied air to the vacuum line to it and received some bubbles. Now if the diaphragm is good should I see zero bubbles at all or a few allowed?
One thing though after the test when I pulled it out of the bucket. The canister was full of water lol so I applied air again and the water came out of the diaphragm area. I took a few bad pics with my blackberry to share and if you look real close it looks like there's a little room next to where the rod goes into the diaphragm which again not sure if that's cool or not so looking for some help
let me know if the bubbles and the gap is exceptable or not... im hoping/praying it's not and my issue has been a beat wastegate actuator.
Daryl H
Re: bad wastegate diaphram?
Do you trust the part or not? A few bubbles is subjective.
Nobody has done the water bucket test that I know of.
Worst case is that it fails and your engine shells out.
How much is it worth to you to re-install a bad part or a known new good one?
Sorry if this does not help you any.
I ought to change out mine also.
2500avalanche
Well-known member
Where can you get a stock on at? Or sufficient replacement? How much do they normally cost.
Flyin Ryan
Well I don't think my engine is going to go boom anytime soon because the issue is lack of boost not boost control. Im thinking or hoping that the wastegate is f'd allowing boost right out the diaphragm.
Did u see any movement of the rod. I would be looking for movement.
Yes some movement but as it moves bubbles come out.. and once it has fully moved more bubbles come out.
gap is fine. bubbles are not.
So John,
I shouldn't have any bubbles at all?
Beavis
Still plays with trucks
Go external and call it a day. They are soposed to be the best way of doing it. I have an external and have never had a problem with it. :2cents:
Flyin Ryan
The turbo has less then 1k on it so this sucks.. and external's are the best way to go for control but Im not in a position to dump another $300 plus weld job cost into this truck at this particular moment.
KDBL1TY
I understand the money deal. I've have been having issues all of last month. Throwing money at it almost never solves the problem. You are moving in the right direction. Go slow and double check everything. There is a turbo relay on the fire wall, which controls the boost solenoid, which operates the wastegate actuator.
Daryl H
If you are having an issue with no boost try to see if the boost solenoid is allowing air through it at idle.
I don't think the small amount of air through the diaphragm will cause low boost.
UR50SLO
V6+2=LSXCamaro
If your applying shop air to it remember there is air trapped in there when you put it in water. When the rod go's out it'll displace that air and "Look" like a leak.
I've never had a turbo car with a external gate. I think they are a waste of $.
Just hook up shop air to it to check movement in/out. If you hear air coming out then there's a problem.
What have you been noticing on the boost level? Up/down? too high? too low?
Some have had the "Puck" or arm on the turbo it's self that holds the wastegate rust and "Stick" when it get's hot. Warm it up and see if it still moves free.
It's not a comon problem that I've ran into that they go bad.
~Scott
Flyin Ryan
hmmm never thought about that.. which vacuum line should I have air movement in during idle off the solenoid?
Scott, sounds about what's going on.. the rod moves but bubbles/air comes out as it moves
Well the issue is I went from 20lbs to zero now.. spark plugs look brand new and all vacuum lines are thick silicone and zipped tied. I double and tripple checked them all and sprayed carb cleaner around the lower as best as I could and along the upper/lower but no change in idle which leads me to the wastegate.
Turbo has less then 1k on it and when I pull the wastegate arm off I can move the puck freely
Only thing Im thinking it could be besides the wastegate canistor/diaphram is the exhaust wheel... but I wanted to rule out the wastegate before I remove my exhaust and downpipe you know.
Daryl H
The solenoid should pass air through it at with the connector off and closes at idle with the connector back on.
(I miss wrote on previous post)
Even with the connector off you should be able to achieve 3-7PSI of boost.
UR50SLO
V6+2=LSXCamaro
With a ruptured actuator diphram...the boost would go to the moon. Since boost hit's the back side of the actuator if it has a leak .. it would not push the rod out.....
This would cause high boost.
I'd take off that inlet to the turbo and see if there is play in the wheel. I'll bet the turbo is the cause since you've got no boost.
What kind of turbo is it? stock replacement?/Larger...? Who built it? Oil restricter up top?
My bet is the turbo is toast. :(
~Scott
Flyin Ryan
Daryl, Yeah i've tried unhooking the solienoid and it made no difference. I've used that trick in the past when tuning and it's worked like it should until this issue popped up.
Flyin Ryan
~Scott
Scott,
hmm I figured with a damaged diaphram it would be leaking boost out but what you said makes sense. The turbo is from rpm and it's a stage1. I've checked the impeller side already a few times and it's brand new looking with no play at all in/out and side to side. Spins like butter but haven't pulled the exhaust and downpipe off the truck yet to check the exhaust wheel which it's not adding up to be I guess.
Is your actuator rod adjusted short enough to keep the wastegate puck closed normally?
Does pulling the actuator rod outward feel stiff? It could be the actuator is premature opening and not keep the wasteagte puck closed to build boost.
