Baer brake problem. Parts needed ASAP!!!
Sy-1177
Turbo Inside
Ok, so on my Ty I have a Baer brake kit installed on the front. Today when I was driving it I did a boost launch and when I let off the gas I could hear something dragging. So I pull over to inspect and see nothing out of the ordinary. So I limp it home and pull the front wheels for a better look. Right off I notice my calipers are a little out of alignment. So I go and touch it and it moves pretty freely.....WTF... the pins that hold the calipers down are fricken gone!! So I look at the drivers side and this is what I see:
Notice the pin thats supposed to be there but not on the top hole?
And here is the passenger side:
Now the pin is a very similiar setup to a regular S-10 where the pin holds the capilers in place to the bracket but the pads "float" in there. Basically does anyone know where I can get these pins? Would I have to go directly to Baer?
LIL QIK
HELL YEA I GOT BOOST!
Re: Baer brake problem. Parts needed ASAP!!!
I recently bought a Baer set from a member that was missing some parts. Baer was very helpful in helping me get the parts and the prices didn't seem to be that bad. Plus I also had the peace of mind knowing it was the right stuff.
sy#2716
SyTy 4 Life
Looks like wheel bearing to me you are going to have to replace the whole spindle because it it is a sealed bearing, or so you have the spaces for the capiler. For my bear kit i have it has spaces to push the caplier out a little bit.
Sy-1177
Turbo Inside
Well I have a buddy thats checking on the pins for me as his work is a Baer distributor. If not, it looks like i'll be calling them.
I don't think the wheel bearings are bad although that bracket that goes around the caliper is almost touching the back of the rotor which I thought was kind of starnge. I'm not sure if thats normal or not.
I had the same exact problem 4 years ago or so with my Baer Brakes (Only one of my caliper slipped past the pin.)
http://www.syty.net/forums/showthread.php?t=21614&page=2&pp=15&highlight=Baer
The pins (washer & C clip) are available from GM from 88-96 Corvette J55 Brakes. I did some research on the Corvette brakes and it didn't seem like that common of a problem, but what I found some brake pads are on the loose side of tolerance. My Baer brakes were still prety new at the time it happened, Baer replaced my caliper brakects, with tighter tolerance brackets.
Sy-1177
Turbo Inside
Ahhhh, now thats good to know! Another buddy of mine used to work at Summit and he said when they sold the baer brake kits they used to get people complaining about loosing those pins all the time. Seems like it happens quite frequently. :roll:
Thanks for the part info, i'll check it out today!
Ok, so I called the local dealer and he faxed me over what they show for parts. From what I can tell they use a pin with a screw in the end of it. Does that sound right? It doesn't look like the pin pictured above with the "C" clip on the end to hold it in place. Is the GM pin interchangeable with the baer kit?
Edit again, the guy must have pulled up the light dudty brakes. A guy here at my work has a 93 Vette and I went and looked at his, its identical to my kit!! Same stupid pins/ and c clips!! :roll: Dealer has to order the pins of course since they don't have any in stock.
Sy-1177
Turbo Inside
Well, a BIG THANKS goes out to Dave for the great info!! I went to the dealer for the parts and the closest dealer that had them in stock was 200 miles away so they had to order them in. They said they should be here by next tuesday or wed.... cuttin it a little too close for Homecoming!! So today I reluctantly called Summit (no luck there) and Auto Zone for the heck of it. Auto Zone had them in stock!:eek: I run up there and grab the pair with "C" clips for $5!!! Granted I paid around $20 from the dealer for the other ones. I brought them home and replaced both sides in a matter of 5 mins! :tup: Woohoo... I love it when something actually works out to my favor with these trucks!
LIL QIK
Far out.....congrats. Guess I'll log the info just incase I have the same problem. Good info.
Loeryder
The Baer street series calipers are the same as the pbr calipers used on the vettes.
Mine do not even say baer on them anywhere and pbr is cast into the back side of the calipers I believe.
& Dave is the holy grail of vette info. :bowdown:
