Balancer Issue
Norm
I have a fluid damper that I got with my Ty. The problem is that it hits the timing cover indexer mark. I could just cut off the mark and still use the fluid damper. Anybody else use one of these or should I just put a stock balancer on . Here's a pic of the issue at hand.
Tooky
Serious about performance
Re: Balancer Issue
Don't forget our motors are all externally balanced, so if you replace the balancer you run a good chance of throwing your bottom end out of balance!! Unless you had your motor rebuilt and paid big bucks (>$500) to drill the crank counterweights and install heavy metal to convert it to an internally balanced engine...
