Ball Bearing Turbo
Vaders Sy
I purchased my turbo for my Sy back almost 9 years ago from PTE. I was the last one they built called a "Stealth" turbo. I've read that it is a 67, but not quite sure. Over 9 years i've seen new technology and improvements have been made to turbos. Was curious to see what turbo is the hottest now with ball bearing technology and such. I want to replace my turbo with a newer turbo that is a little larger but I want to keep the A/C if thats possible. Any ideas or direction someone could point me?
qbnkiller
Conflaguration Specialist
Re: Ball Bearing Turbo
A lot of people believe the BB turbos are the second coming, but advances in journal-bearing turbos have allowed them to perform very similarly, cost less to build (and rebuild), and just flat-out make power.
Check out www.bullseyepower.com. Call and talk to David.
It's just a six
Super Member
It seems that when you have a BB turbo as compared to a standard journal bearing turbo w/the same specs,,,the BB turbo will allow you to use a lower stall converter,,maybe as much as 500 RPM stall less?
Not quite sure,but that seems the way it is on threads I have read.
bezerk
i have upgraded my pt61 with a dual ball bearing pt67 and driveablity is way better. than again, i haven't really tuned it on the pt61. but the higher stall makes it more njoyable to drive with the dual bearing than the non. it felt laggy on part. throttle
