Ball joints & bushings
Bill Z
Re: Ball joints & bushings
I bought the Neoprene bushings from Summit Racing. Ball joints I got from Moog. Rides a tad stiff but will last forever.
Good Luck.
ghettosled
SYTY SUPERSTORE
i stock the CQ ball joints if that helps.
Carquest #31032
Carquest #31314
please email me if you need assistance.
steve-o
When I did my front end, I couldn't find a ball joint and bushing kit available. I did end up buying them separate from napa. I opted to replace my worn bushings with oem type pieces. I hate squeaky suspension.
#2875
built, not bought
the napa premium joints rock. they are way better than the moog ones but more expensive as well.
BacDoc said:
Bump cause I need ball joints.
BacDoc
I priced them there for thirty something a piece?
Vertigo
Addicted to Turbo AWD
In theory the kit should work fine being as the ball joints are the same as the 'regular' 4wd trucks. I'd be a little weary about the quality however. For the time and effort it takes to replace these things (especially if your current ones are stock) I'd go with the Moog's, Napa's etc.
I'm in the process of R&R the upper a-arm bushings after new lower ball joints made no difference in the 'wandering' I'm experiencing. I'm hoping after the new lowers, new bushings, and a pitman arm I can finally relax while driving this truck.
BacDoc
Wandering...that's a good way to put what my truck does.
Vertigo
To be honest, it's more like a snake on acid.
I'll let you know if I get it fixed :)
BacDoc
I just got a quote from Autozone.
$160 for upper/lower ball joints. Outter tie rods. Idler arm. Pittman arm.
And $250 for labor.
Vertigo
Okay my 1992 Ty is almost cured from the 'wandering'.
It was a bad idler, pooched lower balljoints, and dried out upper bushings. The last thing that will help will be a steering box and shaft, but it's totally driveable at this point.
good luck :)
