Balljoint Angle
Daveman2
Autox Blazer
Hey I was wondering about the Sy/Ty Arms, I have my stock 4WD susp. arms and was thinking that your guy's trucks are meant to ride a good 2" lower than mine stock, so I think my balljoint angles from a 4" drop are killing my balljoints, and stock sy/ty arms might give me better geometry.
Could I run a stock Sy/Ty upper arm? I'm pretty certain it's the same dimensions overall, but it might be slightly tweaked,. and Im thinking the balljoint angles would be alot better and mine would stop getting destroyed.
Daron
Re: Balljoint Angle
I am pretty confident GM did nothing to alter balljoint angle in SyTys. It is pretty atrocious stock.
Daveman2
Autox Blazer
Re: Balljoint Angle
Wow that's pretty retarded:roll:
fawk do tubular arms fix them?
How do you guys fix the problem of your balljoints getting destroyed?
sly dvl
Ya, it's got a Turbo
Re: Balljoint Angle
4WD S-10's have been chewing up ball joints since the mid 80's and well into the Y2K.
No remedy, just replace them with a quality part, not a cheap white-box brand.
Lower B/J's on our trucks are load carrying and are allowed to have some play. Uppers are not.
Daveman2
Autox Blazer
Re: Balljoint Angle
what brand do you lowered guys buy?
edit: I see you guys used moogs, anyone tried a heavy-duty unit? Mine get fawked up REALLY fast. my frame is just a little too low for a low-clearance jack
shouldn't aftermarket arms fix this?
sly dvl
Re: Balljoint Angle
Delco, Moog, TRW,
Don't know about lowering arms. I don't think the SyTy's are actually any lower than a stock s-10. They just appear lower because of the cladding and the 16" wheels. But, I'm just guessing here...
Re: Balljoint Angle
I corrected this problem when I designed my coilover kit. That is good news.
Bad news is I don't make them anymore and the "other" kits available didn't address this issue.
GM didn't do a ton of engineering when they did the syty and this is one issue that was left strangling due to that.
