Bandimere Blues..
cheatham2492
Every time I go to Bandimere something stupid always happens.
I have showed up and they have turned me away. Battery not mounted to there liking... blah blah
Shit breaks,plugs go bad Ignition takes a dump etc etc. Not to mention its at 5800 Ft above sea level.
I have shown up and so many times had problems mysteriously begin at this track!
Same shit happend this last time lost a fuse for the fan,a starter or maybe a battery.Can't figure out why its only geting 18 Psi.... and the timing is stuck at 18 Deg. Almost went home.
But i said F$CK it. So they guys brought me a fuse.Some one was kind enough to give me jump.
I kept racing left that bitch run for 3.5 hours straight.Made 8 passes.I showed up off the street in ran a 12.8 @ 106 and it got faster till it got hot.. I was figuring out all kinds of shit.Finally being able to run and make a change and run again.
So last pass with 165 deg MAT temps n and a 1.89 60' " I was spinning all over the place."
I ran a12.3 @ 109.Was going for it again and they said were closed 9 o clock......
I was like figures just when I get it going.....
Bandimere Blues.
I'll be back!!!
D.
V8 Sonoma GT
Mile High SyTy
I have had bad luck there too...alternator went out, couldn't figure out why I was going slower. Had starter go out another time. Once I traliered up, that was a total disaster/fiasco that ended with only 1 pass.
I think I like pueblo better for that. Although I was there last night, and the track was dead for at least 1 of the 2 hours I was there....kinda lame
Sent from my DROID2 using Tapatalk 2
Ry368
one mile = 5280 feet
Re: Bandimere Blues..
Bandimere EATS syty owners dreams up in a hurry! The battle in well worth it though.....hang in there Cheatham!!
AUSyTyIN
Unbusted $#it box
Bandi hates SyTy's. Seems like everyone has issues once they get there.
TYTILIDIE
METH HEAD
I don't think 12.30 is that bad for the Stealth 70. JER ran a similar turbo and ran 12.20. Considering you are running 22psi and for our altitude I think you are right on track maybe just a couple tenths behind. I think you will need to run 24+ to get in to the 11's. Just my opinion though.
cheatham2492
Actually looking at the logs.I could only get 18-19.5 Psi.The timing was stuck at 18' till I enabled the knock sensor back.Then it was 24' It was still running rich 10.2 AFR. So I turned off the Alcohol got an 11.3AFR.I did post the the truck was never turned off 4 hrs while I was hot lapping it right?It was hot as a pistol... My Intake Air Temp's at the beginning of the 12.3 run was 170F.
To prevent that I need to fine tune the Alcohol for the rest of the mixture.Figure where my boost leak is. Get that little odyssey battery away from that hot ass turbo,that way I can turn off the car let it cool make changes and start it back up when I need to.I might bring some ice to lay on top of the manifold to cool shit down. I burned the piss outta my hand.
But Mikie you were right about those tires.I need something with a big side wall that sticks at Bandi I was rosting um through the 60'. The track was cold though.The last two runs I Boost launched in the dry path before to heat the tire sum.The launch was beter 1.82 but still spinned um.
It launches harder out side in front of my house.
There's an 11' in there.
My humble opinion LOL
Cheatie
AUSyTyIN
Unbusted $#it box
Cheatie
I was pulling 1.80s on my dry rotted tires, 100% stock (except AFPR) '92 Ty. Drop a tenth off your 60', and you'll be at an 11.
