base fp and spark plug gap
11secty
hey just need to be refreshed as to what is our trucks base fp suppose to be and what gap to run on a big turbo setup
i have 50lb injectors and afpr
11secty
Re: base fp and spark plug gap
hey thanks you've always been a big help my truck sat for the last 2 yrs and just brought it to muscle car shoot out and ran horrible but my best trap speed was 107 with out boost launching and 1 st to 2nd short shift and accidentally putting it over drive so when i went through the light my rpmS wereabout 3300 isnt there a trick or a reason why it short shifts like that? bad tps?
Tooky
Serious about performance
Wow, you went through the traps at 3300? That sounds a little bizarre, the math in my head doesn't match up to what RPM a stock 3.42 truck would normally turn at 107MPH in 4th gear. At least you know your converter and TCC are holding really well! :lol:
Is your TV cable adjusted properly? It directly controls your shift points (in concert with the governor and a handful of other valves, heh.)
11secty
yeah isnt there a trick to adjusting the tv cable i know ive read it on here a million times
cheatham2492
Yes you need more adjustment of the TV cable.You need more TV pressure. Pull the cable out a couple notches make sure that you can still push the throttle it to WOT.Too much adjustment will prevent the throttle from opening all the way.You could also get a new governor or add some equal weight to the one you have.That will make it shift later. A new pump boost valve will add a little more to the shift as well.HTH
Cheatham
